| Thread Closed |
Semi-hard Projectile Motion Problem. |
Share Thread | Thread Tools |
| Oct8-06, 02:07 PM | #1 |
Ok, I've just come across a confusing projectile motion problem. I have my own solution for it from the work that I have done so far. Please help me finish the problem for the information I have so far. Thanks a lot!
Problem: A fireman, 50m away from the burning building, directs a stream of water from a ground level fire hose at an angle of 30 degrees above the horizontal. If the speed of the stream as it leaves the hose is 40 m/s, at what height will the stream of water strike the building? My solution so far from the work I have done. Ok, first I found the x and y independent velocity components of 40m/s at 30 degrees above horizontal. Vy=20m/s; Vx=34.64 m/s I found the time to the highest point, 2.041s; therefore the time of the total flight is 4.082s. Then I found x (total distance traveled) which is 141.4m Then I found the highest point which is 20.41m But the I realized that I had to find the height of when it reaches the building 50 meters away... I have all the information for the TOTAL FLIGHT. How am I suppose to find the height of when the distance is 50m?? Do I substitute 50m for X=Xo+Voxt+.5AxT^2?? Then I find the time of that distance, then the hight?? What am I doing wrong here?? At first, I wanted to find all the info of the TOTAL FLIGHT then try to come up with a coordinate for 50m, but now I realized that it would be hard to graph it. I don't know what to do, I haven't really done a lot of these problems before. However, I understand the basic concepts of how to find the information of these kind of projectile motion problems. Thanks a lot for you help!
| Oct8-06, 02:15 PM | #2 |
Recognitions:
Since, [tex]x(t)=v_{0x}t[/tex], you can easily find the time it takes to reach the building by plugging in the distance from the building and the x-component of the initial velocity. Further on, use that time in the equation of displacement for the y-direction to obtain the height.
| Oct8-06, 02:22 PM | #3 |
So is this correct?:
50m=Vxo*t 50m=34.64m/s*t t=50m/(34.64m/s) Then you plug the time in for y=Vyot+.5gt^2: y=20m/s*t+.5(-9.8m/s^2)(t)^2 So that would be the height of where the water hits the building at 50m away? |
| Oct8-06, 02:25 PM | #4 |
Recognitions:
Yes, it should be, after you plug in t = 50/34.64 sec.
| Oct8-06, 02:26 PM | #5 |
Alright, thats what I was thinking of before. I get it now, thanks for your help!!
I wasted all my time finding the total information =P
| Oct8-06, 02:34 PM | #6 |
you need to find the time when the horizontal displacement is 50, and then find the vertical displacement at that point.
I got t= 5/3 |
| Oct8-06, 02:36 PM | #7 |
maaan, you guys reply so fast!
| Oct8-06, 02:47 PM | #8 |
Avg. V= X/t t=X/V So the displacement would be 50m and the Avg. velocity or Vxo would be 34.64m/s. I already found the Vxo component in the beginning. Therefore the time would be: 50m/34.64m/s Btw, the answer that I got for the height of the building that the water hits is: 18.66 meters. 18.66m makes sense because the highest point(total) would be 20.41m. The highest point's time is 2.041 seconds. For the time of 50m I got 1.4434s which would make the 18.66m be pretty accurate. |
| Oct8-06, 02:48 PM | #9 |
Can anyone check to see if 18.66 m is the correct height? Thanks
| Oct8-06, 04:02 PM | #10 |
Y = 20*1.44 - 0.5*9.8*1.44^2 = 18.64 Hooooray |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Semi-hard Projectile Motion Problem.
| Help! Two fused semi-infinite rods - hard integral | Calculus & Beyond Homework | 0 | ||
| Hard Projectile Motion Problem. | Introductory Physics Homework | 31 | ||
| Hard Projectile Problem | Introductory Physics Homework | 11 | ||
| Projectile Motion Problem. Very HARD | Introductory Physics Homework | 5 | ||
| Hard projectile motion problem | Introductory Physics Homework | 2 | ||
