How Do You Derive 4-Acceleration from 4-Velocity?
  • Context: Graduate
  • Thread starter Thread starter JabberWalkie
The discussion focuses on deriving 4-acceleration from 4-velocity using the equations provided in Hartle's text. The 4-velocity is defined as u = (gamma, gamma*v), where gamma = 1/Sqrt(1-v^2) and v represents the 3-velocity with c=1. The calculation of du/d(tau) leads to the conclusion that the components of 4-acceleration are v*a*gamma^4 and a*gamma^4, confirming that the 4-acceleration vector is Minkowski-perpendicular to the 4-velocity. The magnitude of the 4-acceleration is established as gamma^3 times the magnitude of the coordinate acceleration.
  • Understanding of 4-velocity and 4-acceleration in the context of special relativity
  • Familiarity with the Lorentz factor (gamma) and its derivation
  • Basic knowledge of calculus, particularly differentiation with respect to proper time (tau)
  • Concept of Minkowski space and its geometric implications in relativity
  • Study the derivation of the Lorentz factor (gamma) in detail
  • Learn about the properties of Minkowski space and its implications for 4-vectors
  • Explore the relationship between proper acceleration and coordinate acceleration in special relativity
  • Investigate hyperbolic motion in relativity and its mathematical foundations
Students and professionals in physics, particularly those focusing on special relativity, as well as educators seeking to clarify concepts of 4-velocity and 4-acceleration.
JabberWalkie
4-velocity --> 4-acceleration?
Hey all, my first post here.
Now, I am trying to derive the 4-acceleration from the 4-velocity by explicitly calculating du/d(tau). So from Hartle we have
u=( gamma, gamma*v)
where gamma=1/Sqrt(1-v^2)
and v is the 3 velocity, taking c=1
So then,
du/d(tau)=( d(gamma)/d(tau), d(gamma*v)/d(tau) )
from the book we have
du/d(tau)=(gamma*(a dot v), gamma*a)
so then we should have
d(gamma)/d(tau)=gamma*(a dot v)
but when i calculate d(gamma)/d(tau) i get...ok I am going to show all my steps so people can know what I've done...
d(gamma)/d(tau)=[d(gamma)/dv)]*[dv/dt]*[dt/d(tau)]
=[d(1/(1-v^2)^(1/2))/dv]*[a][gamma]
=[(-1/2)(-2*(v)/(1-v^2)^(3/2)]*[a]*[gamma]
=[ va/(1-v^2)^(3/2)*[1/gamma]
=v*a*gamma^4 != v*a*gamma
does anyone know what's going wrong or what I am doing wrong??
Any help would be appreciated, Thanks in advance.
You should expect that "proper acceleration", which can be defined as the magnitude of your 4-acceleration, is related to coordinate acceleration by a factor of gamma^3, not by a factor of gamma.
See for instance http://en.wikipedia.org/wiki/Hyperbolic_motion_(relativity )
(which has this result, but doesn't work through the math, unfortunately).
But if we work through your example, we get for the two components of the 4-acceleration
v*a*gamma^4, a*gamma^4
Note that this makes the 4-acceleration vector Minknowski-perpendicular to the 4-velocity, this is another known result.
Now when we take the squared magnitude of the above we get
(1-v^2)*a^2*gamma^8 = a^2*gamma^6
so the square root of this is a * gamma^3, i.e. the magnitude of the 4-acceleration is gamma^3 times the magnitude of the coordinate acceleration, which is what we expect.
  • · Replies 23 ·
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 17 ·
