Is There Friction Between Objects Without an Exerted Force?
  • Thread starter Thread starter Dorothy Weglend
    Friction
The discussion revolves around the concept of friction between two blocks, specifically addressing whether frictional force exists without an exerted force. The original poster, Dorothy, presents a scenario involving two blocks resting on each other and questions the conditions under which friction occurs.
  • Dorothy attempts to clarify the conditions for frictional force between the blocks, questioning if friction exists when no force is exerted. Participants explore the relationship between static and kinetic friction in the context of applied forces and motion.
The discussion is active, with participants providing insights into the nature of friction and its dependence on motion and applied forces. There is acknowledgment of the concepts of static and kinetic friction, and how they relate to the scenario presented.
Participants are considering the implications of static friction and the conditions under which it can be overcome, as well as the definitions and assumptions surrounding frictional forces in the context of the problem.
Dorothy Weglend
Is it correct to say that there is no frictional force if there is no force exerted?
For example, two blocks resting on top of each other on the floor. If I push on the lower block, and there is no motion, then there is a frictional force between the bottom block and floor, which is stronger because of the increased mass from the upper block.
But there would not be any frictional force between the two blocks until the bottom block starts to move. Is this right?
Thanks,
Dorothy
Yes, that's right. Look at it this way. Since friction is the only horizontal force available to the top block, you know that if that block is not accelerating then the friction on it must be zero.
Oh, great. Thank you.
But if the lower block is pushed hard enough that it slides out between the upper block and the floor, then do I consider the static friction between the blocks?
It seems to me I have to, even though the block is sliding at that point, the force must be great enough to overcome the static friction between the blocks, so I have to use that to calculate the strenth of the push.
THanks so much!
Dorothy
Static friction will do as much as it can (up to its maximum value) to prevent sliding between the blocks. But if the lower block is pushed too hard, the needed acceleration for the top block to move with the bottom block (and thus not slip) may be too great for static friction to provide. And once it starts sliding, kinetic friction is what's going on.
Thank you, Doc Al. That's great. Wonderful.
Dorothy
  • · Replies 58 ·
  • · Replies 18 ·
