How Does Particle Motion on an XY Plane Change Over Time?
The acceleration of a particle on a horizontal XY plane is defined by the equation a = 3ti + 4tj, where acceleration is measured in meters per second-squared and time in seconds. At t = 0, the particle's initial position vector is r = (20.0m)i + (40.0m)j, and its initial velocity vector is v = (5.00m/s)i + (2.00m/s)j. By t = 4.00 seconds, the position vector can be calculated using kinematic equations, and the angle between the particle's direction of travel and the positive x-axis can be determined using trigonometric functions. The recommended approach is to treat the motion along the x and y axes as separate one-dimensional problems before combining the results.
  • Understanding of kinematic equations for motion in two dimensions
  • Familiarity with vector notation and operations
  • Basic knowledge of trigonometric functions for angle calculation
  • Ability to perform calculus operations for integrating acceleration
  • Study kinematic equations for two-dimensional motion
  • Learn about vector decomposition and addition
  • Explore trigonometric functions for angle determination
  • Investigate calculus applications in motion analysis
Students in physics or engineering courses, educators teaching mechanics, and anyone interested in understanding particle motion in a two-dimensional plane.
kara
The acceleration of a particle on a horizontal xy plane is given by a=3ti + 4tj, where a is in meters per second-squared and t is in sec. At t=0, the particle has the position vector r=(20.0m)i + (40.0m)j and the velocity vector
v=(5.00m/s)i +(2.00m/s)j. At t=4.00 s, what are its position vector in unit-vector notation and the angle between its direction of travel and the positive direction of the x axis?
I'll say the same thing here as in the other problem: treat the axis as separate problems, solve both, then put the problem back together. By this point in class you've done 1d problems plenty - break this down into two separate 1d problems, figure out the i and j positions, then draw a picture of where the particle is and find the angle.
9K
