Rotational kinematics and grinding wheel
The discussion focuses on solving a rotational kinematics problem involving a grinding wheel with an initial angular velocity of 22 rad/s and a constant angular acceleration of 32 rad/s². The wheel operates for 1.7 seconds before a circuit breaker trips, after which it coasts to a stop while covering an additional angle of 433 rad. The total angle turned is calculated to be 516.64 rad. To determine the exact time it takes for the wheel to come to a stop, users are advised to apply the kinematic equations for rotational motion, specifically Δθ = ω0t + 1/2αt².
  • Understanding of angular velocity and angular acceleration
  • Familiarity with kinematic equations for rotational motion
  • Ability to perform unit conversions for angular measurements
  • Basic algebra skills for rearranging equations
  • Learn how to apply the kinematic equation Δθ = ω0t + 1/2αt² in various scenarios
  • Study the concept of angular deceleration and its calculations
  • Explore the relationship between linear and angular motion
  • Practice solving additional problems involving rotational dynamics
Students studying physics, particularly those focusing on rotational kinematics, as well as educators seeking to enhance their teaching methods in this area.
ACLerok
i've been doing some physics problems out of the text and I was wondering: If an electric fan were to be turned off and you knew its angular acceleration, it is possible to find the number of revolutions it makes in a certain time interval?
also, i having a difficult time with this problem.
At t=0 a grinding wheel has an angular velocity of 22. rad/s. It has a constant angular acceleration of 32. rad/s^2 until a circuit breaker trips at time t=1.7 s. From then on, it turns through an angle 433. rad as it coasts to a stop at constant angular acceleration.
I was able to find the total angle the wheel had turned between t=0 to the time it comes to a rest to be 516.64 rad, but now i have to find at what exact time it comes to a stop.. any pointers and tips are greatly appreciated.
thanks
thanks
1. find the rotation speed when the breaker tripped (Wf = Wi + a*t)
2. find the deceleration from when breaker tripped (Wf^2 = Wi^2 + 2ad)
3. find the time it took took to decelerate (d = Wi*t + (1/2)a*t^2)
That should work.
Yes, it is possible to find the number of revolutions a fan makes in a certain time interval if you know its angular acceleration. This can be done by using the equation:
Δθ = ω0t + 1/2αt^2
Where Δθ is the total angle turned, ω0 is the initial angular velocity, α is the angular acceleration, and t is the time interval.
In the case of the grinding wheel problem, you can use the same equation to find the time it takes for the wheel to come to a stop. You already have the values for ω0, α, and Δθ, so you can rearrange the equation to solve for t. Once you have the time, you can subtract 1.7 seconds (the time when the circuit breaker trips) to find the exact time the wheel comes to a stop.
As for tips, make sure to pay attention to the units of your values. In this problem, the units for angular velocity and acceleration are in radians per second and radians per second squared, respectively. Also, double check your calculations and make sure to use the correct formula for the given scenario. Keep practicing and you will get better at solving these types of problems. Good luck!
