Proving the Normality of ||A||_1 for A in Mat_n
  • Thread starter Thread starter Dragonfall
The discussion revolves around proving that the defined norm ||A||_1 for matrices A in the space Mat_n is indeed a valid norm. The original poster seeks to establish the properties of this norm, including the existence of the supremum and the satisfaction of norm axioms such as the triangle inequality.
  • Participants explore the existence of the supremum in the norm definition and question whether the norm would hold if evaluated at a fixed vector instead of over all vectors. Some suggest simplifying the problem by considering specific matrices or vectors.
There is a productive exchange regarding the properties of the norm, with some participants providing insights into the continuity of the mapping and the implications of the extreme value theorem. Questions about the necessity of verifying the supremum's existence and the triangle inequality are raised, indicating ongoing exploration of these concepts.
Some participants note the importance of the norm's codomain being the reals and the implications of defining a norm based on a fixed vector, which could lead to contradictions with the norm axioms.
Dragonfall
"Let [tex]Mat_n[/tex] denote the space of [tex]n\times n[/tex] matrices. For [tex]A\in Mat_n[/tex], define the norms [tex]||A||_1[/tex] as follows:
[tex]||A||_1=\sup_{0\neq x\in\mathbb{R}^n}\frac{||Ax||}{||x||}[/tex],
where ||x|| is the usual Euclidean norm.
Prove that this norm is really a norm (triangle ineq, etc)"
I don't know how to even prove that the supremum exists.
Supremums always exist. That's why the extended real numbers are so nice! :smile:
I don't see why you would need to prove the supremum is finite, but you could always start by trying to solve simplified problems. (e.g. pick nice matrices, or restrict the supremum to a nice set of vectors) Or, you could try invoking interesting properties about the map x->Ax.
Would it be a norm if instead of looking at the sup over all x, you looked at some fixed x?
If v is any nonzero vector, then v' = v/|v| is a parallel vector to v of unit norm. Observe that |Av|/|v| = |A(|v|v')|/|v| = ||v|Av'|/|v| (by linearity of A) = |v|(|Av'|/|v|) = |Av'| = |Av'|/1 = |Av'|/|v'|. So the above definition for the norm of A is equivalent to the supremum of |Ax| over all x of unit norm. The set of x of unit norm is the unit (n-1)-sphere, which is compact in the usual topology of Rn, and you can prove that the function which maps x in the unit sphere to |Ax| is continuous by showing that it is the composition of two functions, the Euclidean norm function and the function A, and that each of these functions are continuous. Since this composition is a continuous function from a compact set to R, the extreme value theorem tells you that it obtains a maximum, which in turn tells you that the supremum exists.
Proving that this function |.|1 really does satisfy the norm axioms is easy, especially after realizing that:
[tex]||A||_1 = \sup _{x\in \mathbb{R}^n,\, ||x|| = 1}||Ax||[/tex]
No, it wouldn't be a norm if you looked at some fixed x. The map on the plane A(x,y) = x will map (0,1) to 0, so if we define the "norm" of A as |A(0,1)|, then we'd get a non-zero matrix with zero "norm", contradicting the norm axioms.
Since a norm, by definition, has the reals as its codomain (and not the extended reals), you do have to verify that the supremum always exists.
Sorry, I meant would it satisfy the triangle inequality. That's the part I was trying to show how to prove.
Ok, I got it. Thanks.
  • · Replies 20 ·
