What Happens to the Force Between Two Touching Charged Spheres When Separated?
  • Thread starter Thread starter TheMadCapBeta
    Electrostatics
When two conducting spheres, one negatively charged and one positively charged, are brought into contact, their charges redistribute evenly, resulting in each sphere having a charge of Qt/2, where Qt is the total charge. Despite this redistribution, the spheres retain their original signs, leading to both spheres having a positive charge after contact, given that the positive charge has a greater magnitude. Consequently, the net force between the spheres becomes repulsive, as they now possess equal magnitudes of positive charge. The force can be calculated using the formula F = (8.99x10^9 N*m^2/C^2)*(Qt/2)*(Qt/2)/r^2.
  • Understanding of electrostatics and charge distribution
  • Familiarity with Coulomb's Law and the formula for electric force
  • Knowledge of conducting materials and their properties
  • Basic grasp of electric charge signs (positive and negative)
  • Study Coulomb's Law in detail to understand electric force calculations
  • Explore charge distribution in conductors and insulators
  • Learn about the behavior of electric fields around charged objects
  • Investigate the effects of distance on electric force between charged bodies
Students of physics, electrical engineers, and anyone interested in understanding electrostatics and the behavior of charged objects in close proximity.
TheMadCapBeta
Two conducting spheres (of the same size), one negatively charged, one positively charged are at a finite distance apart. Magnitude of neg charged sphere < pos charged sphere.
When the spheres are brought together and touched, and brought back to initial distance, what is the net force between the two spheres?
The first question [unwritten here] was computed by finding the force charge between q1 and q1
F = (8.99E9 N*m^2/C^2)*(q1*q2)/r^2
-I know when the two spheres are physically juxtaposed, the charged is then evenly distributed:
Qt = q1 + q2
So, after the distribution, each charge would be Qt/2.
My question is, would the charges then become neutral, therefore there will result in no repulsion or attraction? Or, would the according spheres retain their sign charge but the magnitudes will become equal: Qt/2? Or, would the charge with the larger magnitude be the pervasive charge and both will become positive when touched? Therefore, the two spheres would repulse instead of attract. Since the positive charge was the dominant charge in terms of magnitude, they would become positive.
In any case, the resultant electric force between the would be:
Can anyone verify any of my assumptions?
Thanks
The magnitude of the positive ball is greater, so both charges are left with a slightly positive charge. I think they would then repel each other.
Based on the given information, it can be assumed that the two spheres have opposite charges, with the positively charged sphere having a larger magnitude of charge. When the spheres are brought together and touched, the charges will redistribute and become evenly distributed on each sphere. This means that the net charge on each sphere will be half of the original charge, resulting in both spheres having the same magnitude of charge. This does not mean that the charges will become neutral, as they will still retain their signs (one positive and one negative).
Therefore, the resulting force between the two spheres will depend on the distance between them and the magnitude of the charges. If the distance between the spheres remains the same, the force will be repulsive since both spheres now have the same magnitude of charge. The equation for the force between two charged spheres is F = (8.99x10^9 N*m^2/C^2)*(q1*q2)/r^2, where q1 and q2 are the charges on each sphere and r is the distance between them.
In summary, when the two spheres are brought together and touched, the net force between them will be repulsive due to the redistribution of charges. The charges on each sphere will become equal in magnitude, but they will still retain their original signs.
  • · Replies 61 ·
