Finding the volume of accumulators
  • Thread starter Thread starter TSN79
    Volume
The discussion focuses on calculating the required volume of hot water accumulators for a condominium, given a hot water usage rate of approximately 0.5 l/s. The heat supply capacity was calculated as 147 kW using the formula 4.2 * 70 * 0.5. The purpose of the accumulator is to provide make-up flow capacity, allowing for efficient heating without the need for instant heating every time hot water is used. Understanding the role of the accumulator is crucial for optimizing hot water supply in residential settings.
  • Basic understanding of thermal energy calculations
  • Familiarity with heat exchangers and their function
  • Knowledge of hot water usage rates in residential buildings
  • Concept of flow capacity and its importance in plumbing systems
  • Research sizing guidelines for hot water accumulators
  • Learn about the efficiency of heat exchangers in residential applications
  • Explore thermal energy storage solutions for residential heating
  • Investigate the impact of flow capacity on hot water system design
Plumbers, HVAC engineers, and building managers involved in the design and optimization of hot water systems in residential buildings.
TSN79
I'm calculating the size of the hot water accumulators for a condominuim. I know that the use of hot water is ~ 0,5 l/s (probability considered). The water is heated by an external hot water source through a heat exchanger. What I've done is to calculate the heat supply capacity using;
4,2*70*0,5 = 147 kW
I'm not really sure what to do with this number, or if I need it at all. How can it bring me closer to finding the required volume of the accumulators?
What is the purpose of the accumulator? Is it for make up flow capacity? Shock absorption?
It is to make up for flow capacity as you said, so one wouldn't have to heat up the water directly in an instant each time some is used.
  • · Replies 51 ·
