Connecting multiple AC transformers
Connecting multiple AC transformers in parallel is feasible if both transformers are identical in rating, manufacturer, and model. In this case, two 60W AC transformers can safely supply a total of 120W to a lighting rig with 6 x 12V/20W halogen bulbs, provided their outputs are in phase. It is crucial to avoid exceeding the transformers' total rating to ensure safe operation and prevent potential failures.
  • Understanding of AC transformer specifications
  • Knowledge of electrical phase alignment
  • Familiarity with halogen lighting requirements
  • Basic electrical safety practices
  • Research the specifications for AC transformers, focusing on parallel connections
  • Learn about electrical phase synchronization techniques
  • Explore the power requirements and limitations of halogen lighting systems
  • Investigate best practices for electrical load management in lighting rigs
Amateur electricians, lighting designers, and hobbyists building custom lighting rigs who need to understand transformer connections and safety considerations.
HelenaA
Hi,
I am a newbie so be kind :smile:
I am trying to build a lighting rig using 6 x 12V/20W hallogen bulbs. I have 2 AC transformers each able to deliver up to 60W. Assuming both transformers are supplied by the same 240V AC input, is it ok to connect their outputs together in parallel to supply up to 120W? I understand their outputs would need to be in phase with each other.
Thank you so much
Helena
Make sure the transformers are not only the same rating, but the same manufacturer and model. In other words, identical. It is not good design practice to run 120 watts worth of lights on transformers who's total rating is 120 watts. Don't push it right to the edge.
Thank you for the advice! Much appreciated
Helena
11K
  • · Replies 25 ·
