How do you guys deal with problems having only 2 variable? Good fomula sheet?
  • Thread starter Thread starter Torec_Scrail
    Variable
The discussion revolves around dealing with physics problems that involve only two variables, particularly in the context of kinematics and constant acceleration. Participants are exploring the relevant equations and their applications in various scenarios.
  • Participants discuss the use of specific kinematic equations and express uncertainty about when to apply them. There are mentions of deriving equations from fundamental relationships between distance, velocity, and acceleration. Some participants question their understanding of the equations and their derivations.
Several participants have offered equations that are foundational for solving constant-acceleration problems. There is an acknowledgment of the need to practice applying these equations to various problems. Some participants are exploring the implications of calculus in deriving these equations, while others express concerns about their understanding and application during tests.
Participants mention the challenge of remembering formulas and the potential for confusion during tests. There is also a reference to the level of mathematical knowledge assumed, indicating a range of familiarity with the subject matter among participants.
Torec_Scrail
Hey guys, sorry this is kinda vauge (Can't sleep) How do you guys deal with problems listing only 2 variables, so you can't straight use the 5 main velocity motion formulas? I know some like t=v-vnaught/a
But, how many all are there that are common? I've ran into 2*vnaught/a
But I'm not used to them, and can't quite see always when to use em..
Any tips or stuff I can read on the net on these? And what formulas would you guys put down on a formula sheet? I want to commit those two to memory (I have, but I might forget em in a weeK)
Anyways..I'll try to check on this tomorrow and maybe expand..thx.
Well, I'm not sure. If you knew more math, then once you know the relation between s, v, and a, then you can derive anything. However, I'm assuming you are in high school and you probably don't have the neat math tricks that you will learn later on in your education.
Anyhoo, one golden equation that really helped me in high school physics was:
[tex]s = v_{o}t + \frac{1}{2}at^{2}[/tex]
Most kinematic problems you do in high school will use them and also in your first year university physics.
I don't know what else to say, but that's the start!
Cheers,
-Rick
Oh, I was good at HS Physics, I even help a friend out with his a bit..but, the uni ones are def more complicated..
Well this 1 isn't that complicated..but, worried like freeze up in the test totally forget the velocity is 0
(a) with what speed mst a ball be thrown vertically from ground level to rise to a maximum height of 50m? (b) how long will it be in the air?
31m and 6.4 s
I guess it's kinda like the 1 I helped friend with..ball stays in air for 8 seconds being shot straight up, what was its intial velocity? I just took half and basically saw how fast it hit the ground from it's highest point..
But, like, your eqn...I don't see how some gets t = 2(v initial)/a from it..
the t's kinda cancel so its not square rooted?
I'm not sure how to integrals..so I'm sure that doesn't help..
All constant-acceleration problems can be solved using these two equations:
[tex]x = x_0 + v_0 t + \frac{1}{2} a t^2[/tex]
[tex]v = v_0 + a t[/tex]
All those other equations can be derived from these two. So if you practice how to apply these two equations to a wide variety of problems, you shouldn't have to worry about the other equations. You'll effectively be re-deriving them as necessary.
The one "catch" in using this method is that you sometimes have to solve two equations in two unknowns, so you may need to brush up on that.
On the side note, the equation (2) is just a derivative of equation (1). I.e.
[tex]\frac{dx}{dt} = \frac{d}{dt}\left(x_0 + v_0 t + \frac{1}{2} a t^2\right)[/tex]
[tex]\frac{dx}{dt} = v = v_0 + a t[/tex]
So if you know how to do derivative. You only need one equation :smile:
I would assume that jtbell is aware of that fact. :smile:
If you want to go the calculus route, the only equation you ever really need is a = constant! Just integrate "a" twice with respect to t and you get the equations for v and x. :wink:
But take Torec_Scrail's problem as an example:
I drew a diagram illustrating all the variables, showing which ones are known and unknown, then substituted into the x and v equations and solved them. See the attachment...
