Find Radius of Circle Given Volume of Solid is 10 Cubic Meters
  • Context: Graduate
  • Thread starter Thread starter Roary
    Base Magnitude
The problem involves finding the radius of a circle with a volume of 10 cubic meters, where the base is a circle of radius 'a' and the vertical cross sections are equilateral triangles. The volume is expressed as V = 2 * [sqrt(3) * Integral{0 to a} (a^2 - x^2)] dx. To solve for 'a', one must evaluate this integral and set it equal to 10 cubic meters. The relationship between the height and radius of the triangles is crucial for determining the correct limits of integration.
  • Understanding of integral calculus, specifically volume calculations using integration.
  • Familiarity with the properties of equilateral triangles and their area calculations.
  • Knowledge of the relationship between circular and triangular geometries in volume problems.
  • Proficiency in evaluating definite integrals and setting equations equal to constants.
  • Evaluate the integral V = 2 * [sqrt(3) * Integral{0 to a} (a^2 - x^2)] dx.
  • Set the evaluated integral equal to 10 and solve for the radius 'a'.
  • Explore the relationship between the height and radius of equilateral triangles in volume calculations.
  • Review similar problems involving circular bases and triangular cross sections for further practice.
Mathematicians, engineering students, and anyone involved in geometric volume calculations will benefit from this discussion, particularly those working with integrals and solid geometry.
Roary
The base of a solid is a circle of radius a, and its vertical cross sections are equilateral triangles. Find the radius of the circle if the volume of the solid is 10 cubic meters.
Eq. Triangle: A = [sqrt(3)/4]s^2
V = [sqrt(3)/4]*Integral{-a to a} 4(a^2 - x^2) dx
V = 2* [sqrt(3)*Integral{0 to a} (a^2 - x^2) ]dx
What next?
(Do I use x^2+y^2=a^2 somewhere?)
I would use the fact that the base is a circle then use disks, integrating over the height to get the volume.
[tex]V= \int \pi r^2 dh =10[/tex]
Since the cross section is an equilateral it is easy to come up with the relationship between h and r, the limits of integration would be from 0 to x. Solve for x to get the height of the cone. Use the relationship between h and r to get the radius.
I think that Roary DID exactly what Integral is suggesting: that was how he got the integral as he did.
To answer Roary's question: "(Do I use x^2+y^2=a^2 somewhere?)"
Actually, you already have when you wrote the square of the base of the triangle as a^2- x^2. What you HAVEN'T used is the fact that the volume is 10 cubic centimeters.
What do you do next? You have V = 2* [sqrt(3)*Integral{0 to a} (a^2 - x^2) ]dx so go ahead and evaluate that, then set it equal to 10 and solve for a.
