Earth science, surface energy balance
The discussion focuses on the surface energy balance equation Q* = QH + QE + QG, where QH represents sensible heat flux, QE denotes latent heat flux, and QG indicates ground heat flux. Participants seek to calculate the equivalent loss of stored soil liquid water in millimeters using the provided hourly energy balance data from Alberta, dated July 1, 2003. The conversion factor for this calculation is the density of liquid water, 1000 kg/m³, which is essential for translating energy fluxes into water loss measurements.
  • Understanding of surface energy balance concepts
  • Familiarity with energy flux terminology (QH, QE, QG)
  • Basic knowledge of data interpretation from tables
  • Proficiency in unit conversion, specifically from energy flux to water equivalent
  • Research methods for calculating water loss from energy balance equations
  • Learn about the significance of each component in the surface energy balance
  • Explore data analysis techniques for interpreting energy flux data
  • Study the impact of soil moisture on surface energy balance in different ecosystems
Environmental scientists, hydrologists, and researchers studying surface energy balance and its implications on soil moisture dynamics.
suedenation
Given the equation Q* = QH + QE + QG and the corresponding data (all fluxes in [W/m²]). How can I find the equivalent loss of stored soil liquid water expressed in [mm] (Note: the conversion factor is the density of liquid water, i.e. 1000 kg/m^3)
Thanks very much for your help!:confused:
First of all, what do you mean by QH, QE, QG? Can you tell us what the terms mean in your equation?
Also, you need to give the question in it's full context.
i'm sorry, the question is about surface energy balance. Given Q* = QH + QE + QG, QH = sensible heat flux, QE = latent heat flux and QG = ground heat flux. (All fluxes in [W/m²]) and the table below, I've to calculate the 24 hour totals equivalent loss of stored soil liquid water expressed in [mm] (note: the conversion factor is the density of liquid water, i.e. 1000 kg/m^3)
Table 1: Daily cycle in hourly-averaged energy balance components over grassland in Alberta.
1 July 2003. (All fluxes in W m¡2; data courtesy of Dr. L. Flanagan; file flanagan.txt)End time [MDT]
hr Q¤ QG QH QE
1 -77 -17 -117 23
2 -68 -17 -67 11
3 -38 -25 2 -2
4 -37 -29 2 -2
5 -31 -27 -5 -1
6 34 -19 -26 2
7 134 -4 3 72
8 262 13 42 136
9 312 28 60 212
10 438 31 99 272
11 518 45 162 315
12 632 65 213 316
13 633 68 208 339
14 595 61 200 347
15 563 54 167 337
16 347 34 73 278
17 311 28 53 230
18 209 13 -35 139
19 81 1 -52 111
20 -15 -5 -44 55
21 -62 -11 -103 23
22 -63 -14 -106 17
23 -62 -14 -77 12
0 -66 -15 -101 19
  • · Replies 27 ·
