Help with conservative/non-conservative forces
  • Thread starter Thread starter JasonAdams
    Forces
The discussion revolves around the concepts of conservative and non-conservative forces, particularly in the context of mechanics. Participants are exploring the definitions and implications of these forces, as well as their effects on work and energy in physical systems.
  • The original poster expresses confusion regarding the definitions and implications of conservative and non-conservative forces as noted in class. Some participants suggest using the path concept to clarify the differences, while others provide examples to illustrate how work done by these forces varies based on the path taken.
The discussion is active, with participants providing clarifications and examples to aid understanding. There appears to be a productive exchange of ideas, with some participants indicating that the explanations are helping to clarify their confusion.
The original poster mentions a lack of clarity in the teacher's explanation, indicating that the discussion is partly driven by the need for better understanding of the concepts presented in class.
JasonAdams
I'm confused about conservative and non-conservative forces from a note I took in class. This is basically the note:
Conservative (force of gravity, effort force)
-is the force that does work on an object
-amount of work is independent of the path taken
-it takes the same amount of work to lift a mass to height 'h' regardless of the path
Non-Conservative (force of friction, normal force)
-the work done against the force of friction when a crate pushed on a rough surface depends on the path
(Work done conservative) results in energy changes that are independent of the path, and therefore reversible.
Time1 = total mechanical energy initial
Time2 = total mechanical energy
(Work done non-conservative) results in energy charges that are independent on the path, and therefore may not be reversed.
I don't really get the note, and I don't think my teacher explained it well enough. Can somebody please translate this for me into something easier to understand?
The path concept is a good way to think about it. Lift a weight from the floor to 2m and let it back down to 1m. The total work is the same as if you just lifted it from 0m straight to 1m, because you can extract the extra PE out of the object in the drop from 2m to 1m (the same as you put into lift it that extra meter from 1m to 2m in the beginning). The same kind of thing holds true for an electron in an Electric field, etc., and for any conservative field and related forces.
However, with friction and other non-conservative forces, the path does make a difference. Push a crate 1m forward, or push it 100m forward and 99m back. It takes positive work input all along that path to move the crate, and you can't extract any energy back out anywhere along that path.
Makes more sense?
Yeah, that helps me understand it more.
Primarily in mechanics, weight (gravity) forces and spring forces are conservative; everything else (friction, drag, normal force, applied forces, etc.) are non-conservative. If there are only conservative forces acting, then mechanical energy is conserved:
Initial Kinetic plus initial potential energy equals final kinetic plus final potential energy. Note that work done by conservative forces is the change in potential energy (gravitational potential energy (mgh) or spring potential energy, (1/2kx^2)).
If there are non conservative forces acting that do work, then
Initial Kinetic plus initial potential energy equals final kinetic plus final potential energy plus the work done by the non-conservative forces.
Note that work done by non conservative forces is the change in potential energy (gravitational potential energy (mgh) or spring potential energy, (1/2kx^2).
The work done by non-conservative forces is equal to the change in mechanical energy.
