Predicting Prime Density in Factorial/Primorial Sequences
The discussion revolves around predicting the density and probability of primes within factorial and primorial sequences, specifically examining the expression n!+1. Participants explore various models, including the Cramér model and Merten's theorem, while raising questions about approximations and the implications of their findings.
  • One participant seeks a better asymptotic for predicting the density of primes in factorial/primorial sequences and proposes a modified probability model based on relative primality to small primes.
  • Another participant mentions Merten's theorem as a relevant approximation for the product used in the probability model.
  • A participant suggests that the asymptotic density derived from Merten's theorem is e^γ/n, which aligns with their estimates for primes of the form (n!)^2+1.
  • There is a contention regarding the density of primes for the expression (n!)^2+1, with one participant suggesting it should be half of the previously stated density.
  • Participants express uncertainty about the naming of the extended model and the implications of their analyses regarding the infinitude of primes in the sequences discussed.
Participants do not reach a consensus on the naming of the extended model or the implications of their findings regarding the density of primes. There are competing views on the density associated with (n!)^2+1, and the discussion remains unresolved on several points.
Participants reference specific sequences and the divergence of the harmonic series, but there are limitations in the assumptions made regarding the density predictions and the applicability of the models discussed.
CRGreathouse
I was trying to do some heuristics with the Cramér model, but I wasn't able to find a good asymptotic for a certain quantity and I thought I'd see if anyone had something good. I did check a few sequences on the OEIS first, but I didn't notice anything there.
Essentially, I'm looking to predict the rough density/probability of primes in factorial/primorial sequences. Consider [itex]n!+1[/itex], for example. In the naive Cramér model the chance it's prime is
[tex]\frac{1}{\log(n!)}\approx\frac{1}{n(\log(n)-1)}[/tex]
but since it is relatively prime to 2, 3, ..., n a better 'probability' would be
[tex]\frac{1}{n(\log(n)-1)}\prod_{p\le n}\frac{p}{p-1}[/tex]
My questions:
1. Is there a name for this extended model? I've seen it before, but I don't recall its name. Actually it's a system of models, one for each positive n, in which the probability of N being prime is 0 if N is divisible by some prime less than or equal to n, and prod{p/(p-1)}/log(N) over the primes less than or equal to n. The original model corresponds to n = 1.
2. Is there a simple approximation for the product I use above? Its values are 1, 2, 3, 3.75, 4.375, 4.8125, ... for 1, 2, 3, 5, 7, 11, ...
3. My immediate interest is in http://www.research.att.com/~njas/sequences/A046029 , which I've been working on calculating (checking up to 10,000). If my understanding is correct, the above huristic suggests a chance of 1/n (limiting as n becomes large) for each number to be prime, and as such in the sequence. This in turn suggests that the sequence has an infinite number of elements since the harmonic series diverges. Are there any problems with this analysis?
I can't say I can recall it having a name of it's own.
Yes, Merten's theorem.
Caldwell and Gallot have a paper about the heuristic for the primorials and factorials, http://www.utm.edu/~caldwell/preprints/primorials.pdf
shmoe said:
Yes, Merten's theorem.[/url]
When my eyes ran over the formula earlier today (in my new Crandall & Pomerance), I realized that this was what I needed. I wish I realized that earlier.
This gives
[tex]\frac{e^\gamma}{n}[/tex]
as an asymptotic density, which seems to fit my estimates pretty closely. That suggests an infinite number of primes of the form (n!)^2+1 by the divergence of the harmonic series -- right?
In any case there are no primes of this form from 77 to 7000, by my checking. I'm going to submit this to Sloan's list, with this heuristic (or an improvement?), along with a correction to the entry, when I get to 10,000.
CRGreathouse said:
This gives
Should be half that density if you're looking at (n!)^2+1.
Yeah, sorry. I had it right on my scratch paper.
  • · Replies 17 ·
  • · Replies 17 ·
