Faraday's Law and magnetic field
The discussion focuses on calculating the induced electromotive force (emf) in a coil with 550 turns and a radius of 3.90 cm placed in a time-varying magnetic field described by the equation B = (1.05 × 10−2 T/s)t + (3.00 × 10−5 T/s4)t4. The coil is connected to a 640 Ohm resistor, and the induced emf is determined using Faraday's Law of electromagnetic induction. The correct expression for the induced emf is derived as -N * (π * r2) * (dB/dt), where the area of the coil is factored in, leading to the final expression of the induced emf as a function of time.
  • Understanding of Faraday's Law of electromagnetic induction
  • Knowledge of magnetic flux and its time derivative
  • Familiarity with coil parameters such as turns and area
  • Basic calculus for differentiation of functions
  • Study the application of Faraday's Law in varying magnetic fields
  • Learn about the relationship between magnetic flux and induced emf
  • Explore the effects of resistance in electrical circuits involving coils
  • Investigate advanced topics in electromagnetic theory, such as Lenz's Law
Students and professionals in physics, electrical engineering, and anyone interested in the principles of electromagnetism and circuit analysis.
erik-the-red
A coil containing N = 550 turns with radius r = 3.90 cm, is placed in a uniform magnetic field that varies with time according to [tex]B=(At + Bt^4)[/tex], where [tex]A = 1.05 \cdot 10^−2 {\rm T}/{\rm s}[/tex] and [tex]B = 3.00 \cdot 10^−5 {\rm T}/{\rm s}^{4}[/tex]. The coil is connected to a resistor of resistance 640 Ohms, and its plane is perpendicular to the magnetic field. The resistance of the coil can be neglected.
Find the magnitude of the induced emf in the coil as a function of time. Write your answer as an expression in terms of the variables given in the problem.
I'm thinking that the derivative of magnetic flux can be written as the derivative of (BA). A is constant, so it's A multiplied by the derivative of B.
I get [tex](A + 4Bt^3)(A)[/tex].
The induced EMF is the negative of that multiplied by N.
I typed that in, but it wasn't right.
What did I not consider?
the derivative of the flux with respect to time is going to be
n(area) (d B/dt)
or n*pi*r^2(A+4Bt^3)
I usually neglect the negative sign unless the problem allows you to define coordinates properly.
I see I did not use the radius for the area.
Thank you.
