Question about light and interference
  • Context: Undergrad
  • Thread starter Thread starter ValenceE
    Interference Light
Light in everyday life does interfere with itself, as evidenced by phenomena such as colors in soap bubbles and oil slicks. However, this interference is often not noticeable due to the incoherence of light sources and the wide range of wavelengths present. The short wavelength of light compared to the spacing between objects and surface roughness minimizes observable interference effects. To observe significant interference, smooth surfaces and gradual changes in thickness or separation are necessary.
  • Understanding of light wave properties
  • Familiarity with optical phenomena such as interference
  • Knowledge of coherence in light sources
  • Basic principles of wave behavior in physics
  • Research the principles of light interference in thin films
  • Explore the concept of coherence in light sources
  • Study the effects of surface roughness on light reflection
  • Investigate practical applications of interference in optical coatings
Physics students, optical engineers, and anyone interested in understanding the behavior of light and its interference effects in everyday scenarios.
ValenceE
Hello to all,
I searched the different forums for an explanation but have not found one complete enough yet… the question is about light interference and goes like this ;
Can you explain or point me towards a link that explains why the light in everyday life doesn’t interfere with itself ?
I mean, when I look around me, the ‘continuum’ of space that my eyes scan, is full of an incredibly high number of light beams reflected from an equally high number of surfaces, coming from all directions.
How come, given all this wave carried information, is there no interference taking place ?
What is the property or properties of light that makes it all appear just right ?
Regards,
VE
Science news on Phys.org
Firstly some interfence will be occurring, however, often it will not be noticable since (a) the sources will not be coherent (b) there will be a large range of wavelengths.
ValenceE said:
Hello to all,
Regards,
VE
Light in everyday life often does interfere with itself. Every time you see colors in a soap bubble or an oil slick on a puddle you are seeing the effects of interference. The lenses in eyeglasses are often coated with thin films to make the surfaces less reflective, an effect that is achieved because of interference. The reason light interference is not more prevalent is that the wavelength is so short compared to the typical spacing between objects and the surface roughness of most objects. To see interference effects you need to have very smooth surfaces and at most very gradual changes in thickness or separation.
Longer length waves like sound or water waves can be heard or seen to interfere very readily. The vibrations of strings on stringed instruments exhibit wave interference every time they make a sound.
  • · Replies 54 ·
12K
