Energy Conservation Problem W/Ramp
The discussion revolves around a physics problem involving energy conservation and projectile motion. A block slides down a frictionless ramp and is analyzed for its horizontal distance traveled after leaving the ramp.
  • The original poster attempts to apply the conservation of mechanical energy to find the velocity of the block at the bottom of the ramp and subsequently uses kinematic equations to determine the horizontal distance traveled. Some participants question the equations used for calculating velocity and distance, suggesting potential algebraic errors.
Participants are actively engaging with the problem, offering guidance on the equations used and questioning the calculations made by the original poster. There is a focus on clarifying the approach to finding the velocity and the subsequent distance traveled.
There is mention of a discrepancy between the calculated distance and the expected answer, indicating possible errors in the original poster's calculations or assumptions. The problem is framed within the context of homework help, suggesting constraints on the level of assistance provided.
kmj9k
Hi, I've been struggling with this problem and would appreciate any help:
A 1.8 kg block slides down a frictionless ramp, as shown in Figure 8-28. The top of the ramp is 1.5 m above the ground; the bottom of the ramp is h = 0.20 m above the ground. The block leaves the ramp moving horizontally, and lands a horizontal distance d away. Find the distance d.
Now, I set the mechanical energy at the top of the ramp equal to the mechanical energy at the bottom of the ramp. Using that equation, I found the velocity of the block at the bottom of the ramp.
From there, I used kinematic equations to find the time it took for the box to fall, with a being g. Then, I used the time to find x. I kept on getting 1.1 m, but the answer is supposed to be 1.02 m. What am I doing wrong?? Thank you in advance!
What is your equation for finding the velocity at the bottom of the ramp?
And what is your equation for find how far it travels?
Your method is right, you probably have an algebraic error
My equation was mgh = (1/2)mv^2, where v = the square root of 2gh. I got 5.4249 m/s. And then for the second part, even if you didn't find the time t, couldn't you also just use the kinematic equations for projectile motion at zero degrees? ie, x= initial V* square root of (2h)/g ?
You got the velocity wrong. (Hint: [tex]v = \sqrt{2g(1.5-0.2)}[/tex])
  • · Replies 32 ·
