Thread Closed
3 Questions in regards to WORK AND ENERGY
Share Thread Thread Tools
Oct22-06, 06:52 PM   #1
I am attempting 3 questions I have worked them out but to no avail. I wonder if I am on the right track:
1st Question:
Starting from rest at the top, a child slides down the water slide at a swimming pool and enters the water at a final speed of 5.00 m/s. At what final speed would the child enter the water if the water slide were twice as high? Ignore friction and resistance from the air and the water lubricating the slide.
Here I am using the principal of conservation of mechanical energy that can be rewritten as follows:
Vf = Sqrt(Vo^2 + 2g(ho - hf)
So I assign a random number (I used 5) to hf and I get:
5.0 m/s = Sqrt(0 + 19.6(Ho - 5))
5 = Sqrt(19.6ho - 98)
25 = 19.6ho - 98
ho = 6.2755
So since the H is twice what it would be I used 12.551
And get:
Vf = Sqrt(Vo^2 + 19.6(12.551 - 5))
Vf = 12.16 <------Wrong....is there somewhere I went wrong???
SECOND QUESTION:
A 915-kg car starts from rest at the bottom of a drive way and has a speed of 3.00 m/s at a point where the drive way has risen a vertical height of 0.600 m. Friction and the drive force produced by the engine are the only two nonconservative forces present. Friction does -2870 J of work. How much work does the engine do?
So I used the Work Energy theorum:
Wnc = 1/2m(Vf^2 - Vo^2) - mg(ho - hf)
Wnc = 457.5(3)^2 - 8967(-6)
Wnc = 57919.5
Do you see anything wrong with my math?
THIRD QUESTION:
The power needed to accelerate a projectile from rest to its launch speed v in a time t is 43.0 W. How much power is needed to accelerate the same projectile from rest to a launch speed of 2 v in a time of t?
I am confused by the relationship here....are there any formulas that would apply here?
Thanks SO much!
Matt
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Oct22-06, 07:53 PM   #2
For 1. Rearrange Vf to get an expression for ho, you know hf = 0. Then just stick 2*ho back into your original expression to find Vf.
Oct22-06, 09:40 PM   #3
Quote by Max Eilerson
Do I use the same equation that I used in the beginning?
Oct23-06, 07:51 AM   #4
Does anyone have any ideas for the 2nd and 3rd one?
Thanks!
Oct23-06, 09:55 AM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
For question two, do not forget that the engine is doing work not only against gravity, but also against friction.
For question three, remember that power is the rate at which work is done.
Thread Closed
Thread Tools
Similar Threads for: 3 Questions in regards to WORK AND ENERGY
Thread Forum Replies
Two questions, work-kinetic energy related Introductory Physics Homework 0
More quick work and energy questions Introductory Physics Homework 7
Quick questions on work and energy Introductory Physics Homework 4
Two Power / Work / Energy Questions Introductory Physics Homework 3
Work & Energy Questions Introductory Physics Homework 6
