| Thread Closed |
Class III laser safety |
Share Thread | Thread Tools |
| Oct23-06, 10:02 AM | #1 |
I have a class III laser that I'm doing experiments with. The laser makes a point on a wall. I am starring at this point for extended periods of time. I could potentially star at this point for upwards of 10 minutes at very close range(less than 12 inches). I can't really discern weather or not the point is brighter than an ordinary light bulb or a burning candle. Given the close range and extended period of exposure, is there any danger?
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Oct23-06, 10:49 AM | #2 |
About 1% of the energy from a lightbulb ends in light. The figure for a laser is much, much higher. A laser doesn't give out light on the area of a sphere either, but a small, fixed point.
You might want to reconsider. |
| Oct23-06, 11:17 AM | #3 |
Class IIIb (USA) are potentially dangerous as diffuse reflections (what you see when you point one at a wall). But laser pointers never go above IIIa (<5mw). Anyway, why are you staring at a laser dot in the first place?
http://electron9.phys.utk.edu/optics...r%20Safety.htm http://www.fda.gov/cdrh/radhlth/lpm.html Google "laser eye protection" or similar - these are cheap color filters for your viewing pleasure. |
| Oct23-06, 12:02 PM | #4 |
I'm trying to detect fluctuations in the Earth's magnetic field. The laser reflects off a mirror that is mounted on an ultra sensitive compass like device. The dot is suppose to move whenever the Earth's magnetic field changes.
The laser is just an ordinary laser pointer, and I'm, in essence, doing little more than prolonged pointing. |
| Oct23-06, 03:49 PM | #5 |
Wouldn't it make sense to have the beam projected onto a sensor array and have data recorded off there (as opposed to spending countless hours staring at a dot on a wall...and then, when you do see it move there's just your word to go by)?
| Oct23-06, 04:08 PM | #6 |
Admin
I bought a radial saw which comes with a laser guide. It also came with filter safety glasses, which I use. One should obtain the appropriate eye protection. There should be guidelines for using a class III laser.
| Oct23-06, 04:09 PM | #7 |
Mentor
You definitely need to use a sensor arrangement. Besides the eye safety issue, your brain will play tricks on you after a while, and the dot will seem to move even though it is not moving. The easiest sensor array to use would be a cheap digital camera with continuous recording capability. Adjust the laser intensity down to reduce blooming and overloading the CCD array.
| Oct23-06, 05:32 PM | #8 |
I'd use as non-reflective target as possible, such as a piece of black felt (or something similar) to focus the laser on. Berkeman makes a good point about the mind playing tricks though. ![]() moo __________________ moo (moo') adj. Of no practical importance; irrelevant, such as a moo point (i.e. a cow's opinion). |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Class III laser safety
| intensity of red laser vs blue laser | Advanced Physics Homework | 4 | ||
| Double slit problem, finding λ of second laser given data about first laser... | Introductory Physics Homework | 2 | ||
| Gun safety classes | General Discussion | 3 | ||
| In class final for a graduate EM class? | Academic Guidance | 3 | ||
| CO2 safety | General Physics | 4 | ||
