| Thread Closed |
Linear independence proof |
Share Thread |
| Oct27-06, 06:55 AM | #1 |
Recognitions:
I need to check the proof of the proposition below we got for homework, thanks in advance!
Proposition. Let V be a vector space over a field F, and [tex]S = \left\{a_{1}, \cdots, a_{k}\right\}\subset V, k\geq 2[/tex]. If the set S is linearly dependent, and [tex]a_{1} \neq 0[/tex], and if we assume there is an order on S, then there exists at least one element of S which can be shown as a linear combination of its predecessors. Proof [?]. If S is dependent, then there exists an element in S that can be shown as a linear combination of the rest of vectors from S, so: [tex]a_{j+1}=\alpha_{1}a_{1}+\cdots+\alpha_{j}a_{j}+\alpha_{j+2}a_{j+2}+\cdo ts+\alpha_{k}a_{k}[/tex]. (*) Further on, let's assume that the vector [tex]a_{j}[/tex] can be shown as: [tex]a_{j}=\beta_{1}a_{1}+\cdots+\beta_{j-1}a_{j-1}[/tex]. So, after plugging [tex]a_{j}[/tex] into the equation (*), we get: [tex]a_{j+1}= \alpha_{1}a_{1}+\cdots+\alpha_{j}(\beta_{1}a_{1}+\cdots+\beta_{j-1}a_{j-1})+\alpha_{j+2}a_{j+2}+\cdots+\alpha_{k}a_{k}[/tex], which implies [tex]a_{j+1}=\gamma_{1}a_{1}+\cdots+a_{j-1}\gamma_{j-1}+\alpha_{j+2}a_{j+2}+\cdots+\alpha_{k}a_{k}[/tex]. We assumed that [tex]a_{j+1}[/tex] is a the combination of all vectors in S, so, since the linear combination does not explicitly contain the vector [tex]a_{j}[/tex], we conclude that [tex]a_{j}[/tex] must be a linear combination of the vectors [tex]\left\{a_{1}, \cdots, a_{j-1}\right\}[/tex] with the coefficients [tex]\gamma_{i}[/tex]. Gee, I have the feeling I missed something big here. ![]() P.S. The thread should be called 'Linear dependence proof' or sth like that, but nevermind. |
| Oct27-06, 10:06 AM | #2 |
I think you are overcomplicating it. Just show they add to zero with not all coefficients zero, and then find the first non-zero coefficient starting on the right side, and move this term to the other side of the equation. You should be able to figure it out from there.
| Oct27-06, 11:34 AM | #3 |
Recognitions:
| Oct27-06, 12:00 PM | #4 |
Recognitions:
No, it isn't valid. The 'proof' doesn't not even make any statement about any ordering on the elements a_i, does it?
| Oct27-06, 12:33 PM | #5 |
Recognitions:
| Oct27-06, 12:38 PM | #6 |
Recognitions:
You know there is a subset of the a_i, and a non-trivial relation between them, i.e. one where all coeffecients are not zero. Now what do you need to do?
| Oct27-06, 02:03 PM | #7 |
Recognitions:
Ok, I may have got it now. Since S is dependent, there exist [tex]\alpha_{1}, \cdots, \alpha_{k} \in F[/tex] such that at least one of them is non-zero. Let's assume [tex]\alpha_{k} \neq 0[/tex]. So, from
[tex]\alpha_{1}a_{1}+\cdots+\alpha_{k}a_{k}=0[/tex] we have [tex]-\alpha_{k}a_{k}=\alpha_{1}a_{1}+\cdots+\alpha_{k-1}a_{k-1}[/tex], which we can multiply by [tex]-\frac{1}{\alpha_{k}}[/tex], so [tex]a_{k}[/tex] can be shown as a linear combination of its predecessors. Now, if S is such a set where [tex]a_{k} = 0[/tex], then we can show in the same way that [tex]a_{k-1}[/tex] can be written as a linear combination of its predecessors, and so on. If the set has 2 elements (for k = 2), the element [tex]a_{2}[/tex] can be shown as a linear combination of [tex]a_{1}[/tex], since [tex]a_{1} \neq 0[/tex]. I hope I got this right now. |
| Oct27-06, 04:06 PM | #8 |
Recognitions:
Apart from the fact that there is nothing to suppose that the order on the a_i's is that inherited from the subbscripts....
| Oct27-06, 04:17 PM | #9 |
Recognitions:
| Oct27-06, 05:11 PM | #10 |
Recognitions:
You are assuming that a_k's predecessors are the a_i with i<k. The question does not imply that at all. It just says they are ordered, somehow.
| Oct27-06, 06:35 PM | #11 |
Recognitions:
| Oct28-06, 03:21 AM | #12 |
Recognitions:
But you've done the linear algebra part. The ordering has nothing to do with the linear algebra.
You can pick a subset of the a_i and non-zero coefficients b_i so that the sum b_ia_i is zero. Now, you picked out the one that is largest in the ordering by using the subscripts. Well, since we aren't actually told that it is the subscripts we're using (not as written above), that is not what we should do. We just need to pick out the largest in whatever the ordering is. In particular you may, after relabelling, assume that the ordering on the a_i is precisely the one given by the subscripts. But none of this bit of the question has anything to do with linear algebra. |
| Oct28-06, 04:54 AM | #13 |
Recognitions:
I get it, thanks for your help!
| Thread Closed |
Similar discussions for: Linear independence proof
| 2 Linear Algebra Proofs about Linear Independence | Calculus & Beyond Homework | 2 | ||
| Linear Algebra: Linear Transformation and Linear Independence | Calculus & Beyond Homework | 8 | ||
| Linear Independence Proof | Linear & Abstract Algebra | 3 | ||
| need help with linear independence proof! | Calculus & Beyond Homework | 4 | ||
| Linear independence proof | Linear & Abstract Algebra | 2 | ||
