How Is Acceleration Calculated with Force and Friction Involved?
  • Thread starter Thread starter badboyben03
The acceleration of a 70 kg box pulled by a 400 N force at a 30-degree angle, with a kinetic friction force of 75 N, is calculated using the net force approach. The horizontal component of the pulling force is approximately 346 N, leading to a net force of 271 N (346 N - 75 N). Using the formula a = Fnet/m, the acceleration is determined to be approximately 3.9 m/s². Verification through different methods yields similar results, confirming the calculations are accurate.
  • Understanding of Newton's Second Law of Motion
  • Knowledge of vector components in physics
  • Familiarity with frictional forces and their calculations
  • Basic algebra for solving equations
  • Study vector decomposition in physics for better understanding of force components
  • Learn about different types of friction and their effects on motion
  • Explore advanced applications of Newton's laws in real-world scenarios
  • Investigate the impact of angles on force calculations in physics
Students in physics, educators teaching mechanics, and anyone interested in understanding the dynamics of forces and motion.
badboyben03
a 70 kg box s pulled by a 400 N force at an angle of 30 degrees to the horizontal. The force of kinetic friction is 75 N.
determine the acceleration.
heres what i did
first i found the x-component using (686)sin30 and it comes out to be 343.
Then i use the formula where the sum of forces = m*a and i plug in the numbers. 343=70a. divide by a and accelertaion is 4.9 m/s/s. is that right?
The horizontal component of the tension should be 400*cos(30)~346 N
The sum of forces in the x direction is then 346 - 75 = ma
solve for a ~ 3.9 m/s/s.
Yes, your calculation is correct. The acceleration of the box is 4.9 m/s/s. You can also check your answer by using the formula for acceleration, a = Fnet/m. In this case, the net force is 400 N - 75 N = 325 N, and the mass is 70 kg. Plugging in these values, we get a = 325 N / 70 kg = 4.64 m/s/s, which is close to your answer of 4.9 m/s/s. Great job!
  • · Replies 20 ·
