History of thermohaline circulation
The discussion centers on the historical analysis of thermohaline circulation (THC) and the methodologies used to chart its history, including the interpretation of ice core data and ocean sediment analysis. Participants explore various proxies and indicators that provide insights into past THC behavior, touching on theoretical and experimental aspects of paleoclimatology.
  • Some participants question the reliability of sources like the Greenpeace website, noting a lack of references for claims about ice core data.
  • Others mention numerous publications that discuss changes in THC associated with Greenland Ice core spikes during the last termination.
  • One participant emphasizes the need for specific methodologies rather than general possibilities in studying THC history.
  • It is suggested that indications of THC history can be derived from ocean sediment cores, including biota remains and isotopic ratios.
  • Participants discuss how changes in foraminifera species distribution may indicate shifts in thermohaline currents.
  • Another point raised is that sea surface temperature changes can be inferred from various isotopic and elemental ratios, which are used to deduce THC flow rates.
  • A participant introduces the protactinium to thorium ratio in ocean sediments as a method to indicate past THC strength and activity.
  • Concerns are raised about the interpretation of data, particularly regarding the timing of climatic events and the implications of different proxies.
  • Some participants highlight the challenges in interpreting paleoclimatic data due to the statistical nature of the analysis and the potential for misinterpretation of anomalies.
  • There is a discussion about the interconnectedness of ice sheet dynamics and ocean circulation, suggesting that understanding one requires insights into the other.
Participants express a range of views on the methodologies and interpretations of THC history, with no consensus reached. Disagreements exist regarding the reliability of certain proxies and the implications of findings from different studies.
Participants note limitations in the available data and the challenges of interpreting proxies, emphasizing that conclusions drawn from sediment cores and ice cores may be influenced by various factors and assumptions.
Mk
How could we possibly chart its history? The Greenpeace website cites ice core data as backing them up (what? no references? :smile:), but then we would have to have some gas isotope ratio that is used to pin down some quality.
Could you please be more specific? Anyway there are dozens of publications about changing THC's with the spikes of the Greenland Ice cores at the last termination.
I am asking how it is done, not possible ways it is done.
Ok,
Well obviously no-one in the past has been recording it so we need indications of indications and hints which are found in sediment cores of the ocean floors. Anything what can be measured is measured, biota remains, macro fossils of foraminifera, alkenone contents of the muds, ratios of elements, and isotopes, isotopes of everything you can think of.
Alleged tell tale signs of changes in the thermohaline current is changes in geographic spread of a thousands species of foraminifera,
Furthermore, a fast flow evens out the temperature gradient with lattitude, as the equatorial heat is more quickly transported to the poles. So rates of changes in sea surface temperatures can be used to measure this speed. Sea surface temperatures are decuded from isotope ratios, element ratios (Mg Ca Sr) and alkenone ratios.
So thermohaline current flows are basically deductions of deductions. It may be clear that this is very tricky, since sometimes other events may cause the same type of remaining evidence.
Pa/Th ratios in ocean bottom sediments
The ratio of protactinium 231 to thorium 230 in sediments recovered from the ocean floor in the Atlantic provide indication of when thermohaline circulation was strong, weak, and not operating. Read this article for a start on this subject:
http://www.whoi.edu/mr/pr.do?id=8839
Thanks for the link S,
There are problems though,
They found that the coldest interval occurred when the overturning circulation collapsed following the discharge of icebergs into the North Atlantic 17,500 years ago. This regional climatic extreme began suddenly and lasted for two thousand years.
Curiously enough that cold periglacial surge is just 'busted' by Schaefer et al Science 2006, who observed that both hemispheres came out of the ice age together some 17ka BP, disdaining the Greenland ice core isotopes that insist that it happened some 14,700 years ago at the onset of the Bolling "interstadial".
See also: http://www.ukweatherworld.co.uk/forum/forums/thread-view.asp?tid=2273&posts=20&start=1
Incidently one of the links that you send me today (thanks again) confirms that too:
http://www.geol.lu.se/PERSONAL/DNH/images/SAN1999.pdf
The lowermost radiocarbon date, immediately above the till, indicates that Lake Kullatorpssjo¨n was deglaciated before 14 000 14C yr BP, which corresponds to more than 17 200 cal. yr BP and provides further evidence that the Kullen Peninsula belongs to the earliest deglaciated area in
Sweden.
No, many of the earliest? many other proxies show the same. Actually this widespread early warming is a much better debunker for Greenland and other NH isotopes for being warming instead of precipitation change.
My guess is that the protactinium - thorium ratio variation may have more than one explanation (as usual).
It's a very tough science, in fact they still don't know all that much because they can only work with things like ice cores and sea floor sediment which can be very difficult to interpret. There's some good stuff going on with the "palaeo people" they can look at a shell and tell you if it was deep water, they can tell you about ocean acidity and all sorts of things. The problem is that its based on statistical analysis, if they find some anomaly it might mean something as drastic as an ice age or it could just be an erroneous spike.
Working out what the ice sheets were doing has major implications for what the ocean might have been doing, they are interlinked and should really be understood together. Also where the continents were, where the major basins were are all important. Palaeo current data can tell us some stuff about which direction the currents were going, these are sedimentary features that show orientation like ripples and flute casts, again you need lots of them and have to be aware of over interpreting.
  • · Replies 52 ·
9K
15K
19K
