Spherical aberration and concave mirrors
The discussion revolves around the phenomenon of spherical aberration in concave mirrors, particularly in the context of an experiment where an image was formed when an object was placed at the focal point. Participants explore the implications of spherical aberration and the physical characteristics of the object used in the experiment.
  • One participant describes an experiment where a concave mirror produced an image at a distance when an object was placed at the focal point, contrary to theoretical expectations.
  • Another participant explains that spherical aberration prevents a spherical mirror from producing a perfect point image, suggesting that the image formation observed may be due to this effect.
  • A question is raised about how spherical aberration specifically causes an image to appear when the object is at the focus, noting that the image formed was far from the expected location.
  • A later reply discusses the impact of the thickness of the candle used in the experiment, proposing that this physical characteristic may also influence the observed image formation.
  • One participant confirms that while spherical aberration may play a role, the primary reason for the finite image distance is the defocus caused by the thickness of the light source.
Participants express differing views on the causes of the image formation, with some attributing it to spherical aberration and others emphasizing the role of the candle's thickness. The discussion remains unresolved regarding the primary factors influencing the observed phenomenon.
Participants reference theoretical expectations about image formation at the focal point and the effects of spherical aberration, but do not resolve the implications of these factors in the context of the experiment.
jnimagine
Concave mirror experiment
We did an experiment with a concave mirror
Concave mirror was placed on optics bench and a candle was placed at designated spots. A screen was used to see where the image was projected. But a strange thing happened. When the object was placed at the focal point, image was projected on the screen very far back of the bench. In theory, when the object is placed at the focus, no image is formed but in this experiment, image did form
Can anyone explain why this happened? :confused:
Science news on Phys.org
A spherical mirror cannot produce a perfect point image of a perfect point object. The usual simple spherical-mirror equation for image and object distance applies only as an approximation which gets better as the diameter of the mirror becomes smaller. This is called spherical aberration.
The Wikipedia article on spherical aberration illustrates this with a ray diagram for a lens with spherical surfaces, but the general principle is the same for a spherical mirror. Notice that the rays through the outer portions of the lens come together closer to the lens than the rays through the center of the lens. I think the same is true for mirrors, but my optics books are at the office and I'm at home now. (I better be at home in the middle of the night! :eek:)
How does spherical aberration cause an image to appear when the object is placed at the focus?
In theory, when the object is placed at the focus, no image should appear but when i did an experiment with a concave mirror and a candle, image did appear. But the image was very very far away from the focus but still on the image side.
Does this have anything to do with spherical aberration? or the thickness of the candle? because in theory, ur only talking about a single line and the candle posesses a thickness... maybe that has something to do with the image appearing?
[By the way, please don't start a new thread when you're continuing the same topic. I merged your two threads together.]
Did you follow the link that I gave and look at the ray diagram there? In that diagram, the focal point is at the far right, but most of the rays actually converge to the left of the focal point because of spherical aberration. If we move the object (on the left side of the lens) from infinity to the focal point on that side, the rays that originally converged on the focal point on the right will now go out parallel (to an "image" at infinity), and the rays that originally converged closer to the lens will now converge to the left of infinity, at a large distance from the lens.
With spherical aberration, the image of a point object isn't a point any more, but instead a fuzzy spread-out blob in space. With the object at the focal point, some of that blob goes to infinity, but the rest doesn't.
jnimagine said:
Or the thickness of the candle? because in theory, ur only talking about a single line and the candle posesses a thickness... maybe that has something to do with the image appearing?
You nailed it.
While spherical (and other aberrations) may contribute to this effect, it is the defocus present (i.e. the fact that not all of your light source is in focus) that primarily ensures your image distance remains finite. You would still observe this effect in an aberration free lens.
Claude.
  • · Replies 172 ·
23K
  • · Replies 17 ·
