| Thread Closed |
gravity caused by curved space - am I right? |
Share Thread | Thread Tools |
| Feb8-04, 01:07 PM | #1 |
I went over this with someone here a while ago and I think they became exhausted with me. Anyway, I went away to think about it. Here is what I have so far.
I was told that gravity is caused by warped space time (according to, is it GR or SR). I was told that when you move into a curve, you accelerate. This is what was really confusing me. I tried to picture something moving faster because it was going from a straigh path to a curved one but I just wasn't seeing it. How does moving along a curve translate to increasing speed? Then it dawned on me that one thing I could see was that if the curve was getting tighter and tighter, as 'twere, one thing that does increase and that is the rate at which the object in question is changing directions! So the picture I formed in my head is this: Imagine the earth by itself in space (to avoid distractions). Now pop something into existence, say, a person, some ways away from the Earth. Now this person, having just popped into existence, instead of just floating in space will start to move towards the earth, slowly at first and then faster and faster, making a straight path. Now, this straight line being traced is what we see, but the reason the person is accelerating is because this is not the whole picture. What we see as a straight line path is actually a person changing directions because they are actually travelling in a curve and the reason they are accelerating is because the curve they are caught on is getting more and more curved. In other words, the faster speed we see is the increased rate the person is changing direction on the ever tightening curve. Could someone please tell me if this is what the whole deal is about or have I descended into madness? Many many thanks. |
| Feb8-04, 01:23 PM | #2 |
Yes, it is true that in General Relativity, gravity is pictured as a "warping" of space. In classical, Newtonian, physics, all objects move in a straight line unless they are affected by a "force". General Relativity replaces the straight line with the "geodesic" of a curved surface. The "force" of gravity is replaced by the fact that geodesics are no longer straight lines.
"I was told that when you move into a curve, you accelerate. This is what was really confusing me. I tried to picture something moving faster because it was going from a straigh path to a curved one but I just wasn't seeing it." In physics, "accelerate" does not mean "move faster". "Accelerate" means "change velocity". Slowing down (in common parlance "decelerate") is also a form of acceleration. In fact, since velocity is a "vector" quantity (having both speed and direction) any time you change direction, you are changing your velocity and so are "accelerating". If you move around a circle, with [b]constant[b] speed, since you are constantly changing direction, you are accelerating. Since going around a curve necessarily means changing direction, going around a curve necessarily means "accelerating" but not "going faster". |
| Feb8-04, 01:34 PM | #3 |
Geodesics should not be thought of as straight lines. Think of them as lines of extremal lenght. Or if you wish think of it as a "straightest possible line." But a path, even a geodesic, on a curved surface surface is not a straight line. However if one resides within such a surface then geodesics would appear as straight lines in that sense. Keep in mind that geodesics are the "straightest possible lines" not in space but in space*time* |
| Feb8-04, 01:37 PM | #4 |
gravity caused by curved space - am I right?Not quite, you must be very careful. Objects in free fall always follow geodesics. The fact that spacetime is curved doesn't mean that the line is no longer straight. It is, in fact, a straight line on a curved surface (the same way lines of latitude and longitude on a sphere are straight lines). They "look" curved, because we like to associate the term "straight" with flat space(time) only. But it is important to remember that they are straight. The fact that spacetime is curved and geodesics may not behave the way they do in flat spacetime is what manifests itself as a deflection from an otherwise straight path. |
| Feb8-04, 02:57 PM | #5 |
Sartor resartus. Lines of latitude aren't geodesics on the sphere, except for one, the equator. Lines of longitude are geodesics ("great circles"); the use of the term "straight line" for them is, well,...specialized. |
| Feb8-04, 03:03 PM | #6 |
| Feb8-04, 09:55 PM | #7 |
Hmm, what I'm sort of seeing is that residing on this geodesic means I'm changing direction and I take it this is why I started moving towards the earth in the first place. But you say that this isn't so and mentioned something called "tidal force"... I'll leave it there. |
| Feb8-04, 11:48 PM | #8 |
| Feb9-04, 12:23 AM | #9 |
Here is a Newtonian example: If there is mass at point X then the Newtonian tidal force tensor does not vanish at X. But that doesn't mean that the gravitational field in nearby points must have a tidal gradient there. Here is such an example http://www.geocities.com/physics_wor...rav_cavity.htm Here is a derivation of tidal accelerations in Newtonian language http://www.geocities.com/physics_wor...rce_tensor.htm Here is a derivation of tidal accelerations in Einsteinian language http://www.geocities.com/physics_wor..._deviation.htm |
| Feb9-04, 12:28 AM | #10 |
| Feb9-04, 12:39 AM | #11 |
| Feb9-04, 02:42 PM | #12 |
There has been an unfortunate trend in GR where the deflection of particles was attempted to have been explained in geometrical terms. However GR has never been more geometrical than any other theory. The analogy with curved surfaces has led people to the erroneous belief that it was the actual cause of gravity rather than a different way to describe gravity. But GR is just as geometrical as EM. As Einstein said
| Feb9-04, 03:27 PM | #13 |
Recognitions:
Consider a 1-D space. The worldline is drawn in 2-D space-time, one D for space, and the other D for time. The slope of the world-line is the speed. So, if the world-line is curved, then its slope changes, therefore the speed changes. For higher D space, even if the slope of spatial displacement wrt time displacement is constant, the world-line can have a change in the dx/dy slope, for instance. As you pointed out, this would be a change in direction, which also cannot happen in the absence of acceleration. Just don't forget about the space to time slope. In other words: The dx/dy, dy/dz, and dz/dx slopes are direction. If they change, then there is acceleration by virture of changing direction. The dl/dt slope is speed (dl2 = dx2 + dy2 + dz2). If it changes, then there is acceleration by virtue of changing speed. |
| Feb9-04, 03:50 PM | #14 |
| Feb10-04, 01:23 AM | #15 |
I don't know how many times I've shouted this from the mountain tops, but I KNOW that if I accelerate out into space inside an elevator that it will feel the same way as standing on the earth and things I let go of will drop etc. etc.! I've never thought of as geodesics as "straight lines" except in so far as the appear straight to those residing in the curved space and in so far as they are the shortest path between two points on a domed surface. So here is what I've gotten from you so far. Spacetime curves are sometimes called tidal forces. Gravity, which I understand to be the pull exerted by a mass (what every particle does to every other particle in the universe), is not the result of moving through curved spacetime. Spacetime is merely a way to describe the phenomenon of being pulled towards a mass (don't quite know what that means). This pull that masses exert, which we call gravity, can exist without the presence of curved spacetime. Umm, do we happen to know of a planet or star or something out there which has gravity but does not curve spacetime? |
| Feb10-04, 01:38 AM | #16 |
In GR there is no need for forces.
In fact the basics of GR ar simpel and clear. The curved spacetime defines how particels move (read mass/energy) and mass/energy defines the curvature of spacetime. |
| Feb10-04, 03:21 AM | #17 |
Particles moving through curved spacetime is not an explanation of gravity - it is merely a description of tidal effets in geometrical terms |
| Thread Closed |
| Thread Tools | |
Similar Threads for: gravity caused by curved space - am I right?
| Gravity AND curved space-time bending light | Special & General Relativity | 2 | ||
| Questions about gravity and curved space | Special & General Relativity | 13 | ||
| Could any curved space be a cut in a higher-dimensional flat space ? | Special & General Relativity | 11 | ||
| Losing mass, gravity, curved space, and more | General Astronomy | 8 | ||
| Hovering in gravity makes curved space flat? | Special & General Relativity | 2 | ||
