Why Am I Getting Errors in My C++ Binary Tree Implementation?
  • Context: C/C++
  • Thread starter Thread starter Trista
    Binary C++ Trees
The discussion revolves around a user's implementation of a binary tree for an address book in C++. The focus is on identifying and resolving compilation errors related to the structure of the tree nodes and their pointers.
  • The user describes an error occurring in the `treeContains` function, specifically related to pointer types in the binary tree implementation.
  • Some participants propose that the `left` and `right` pointers in the `treeNode` struct should point to `struct treeNode` instead of `struct node`.
  • One participant confirms the need for `treeNode` pointers, stating that the current implementation is incorrect.
Participants generally agree on the need to correct the pointer types in the `treeNode` struct, but the discussion does not resolve all potential issues in the implementation.
The discussion does not address other potential errors or limitations in the implementation beyond the pointer type issue.
Trista
I'm trying to write an address book that is based on a binary tree. I'm devloping in Visual C++ (I blew up my Ubuntu with the new dist), starting with the basics:
Code:
#ifndef binarySearchTree_h
#define binarySearchTree_h
#include <string>
#include <iostream>
using namespace std;
//Define the node
struct treeNode
//An object of type TreeNode
	string data;
	struct node* left;
	struct node* right;
treeNode(string str)
//constructor: Make a node containing str.
	data = str;
	left = NULL;
	right = NULL;
//define the class
class binarySearchTree
public:
	binarySearchTree();
		//constructor
	bool isEmpty() const;
	bool treeContains(treeNode *root, string data);
		//return true if item is one of the items in the
		//binary sort tree to which root points. Return
		//false if not
protected:
	treeNode *root;
#endif
my problem is in the implementation file in the treecontains() function:
Code:
#include "binarySearchTree.h"
#include <string>
#include <iostream>
binarySearchTree::binarySearchTree() :root(NULL)
bool binarySearchTree::isEmpty() const
		//return true if tree is empty
	return (root == NULL);
bool binarySearchTree::treeContains(treeNode *root, string data)
		//false if not
		if(root==NULL)
			//tree is empty
				return false;
		if(data==root->data)
			//item has been found
			return true;
		if(data < root->data)
			//item is in left subtree
			return treeContains(root->left, data);  //error
		else
			//item is in right subtree
			return treeContains(root->right, data); //error
	} //end treeContains()
I get an error that says:
Compiling...
test.cpp
binarySearchTree.cpp
c:\program files\microsoft visual studio\myprojects\binaryaddressbook\binarysearchtree.cpp(41) : error C2664: 'treeContains' : cannot convert parameter 1 from 'struct node *' to 'struct treeNode *'
Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
c:\program files\microsoft visual studio\myprojects\binaryaddressbook\binarysearchtree.cpp(46) : error C2664: 'treeContains' : cannot convert parameter 1 from 'struct node *' to 'struct treeNode *'
Error executing cl.exe.
binaryAddressBook.exe - 2 error(s), 0 warning(s)
Here is my test file:
Code:
#include <iostream>
int main()
	treeNode *root;  //pointer to the root noode in the tree
	root = NULL;  //start with an empty tree
	return 0;
as you can see it doesn't do anything, but get the constructors working.
please help so I can get this thing going?
thank you
Technology news on Phys.org
Code:
#include <string>
#include <iostream>
//Define the node
struct treeNode
	string data;
	struct node* left;
	struct node* right;
	data = str;
	left = NULL;
	right = NULL;
It's been years since I've used C++ but I think you should have struct treeNode* left; and struct treeNode* right;.
Yep: TreeNode needs pointers to TreeNode, not pointers to struct node.
Cheers,
Tim
You are so right! Thank you!
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 39 ·
