Calculating Tension in a Rotating Hoop
  • Thread starter Thread starter oahsen
The discussion revolves around a problem in circular motion involving a thin circular hoop of mass m and radius R that rotates about a vertical axis. Participants are tasked with determining the tension within the hoop, with a specific hint suggesting to consider a tiny section of the hoop.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between forces acting on the hoop, including centripetal force and tension. There are discussions about drawing free body diagrams and the components of forces acting on different sections of the hoop.
Some participants have provided hints and suggestions for approaching the problem, including the idea of analyzing forces on half the hoop and using symmetry. However, there remains a lack of complete understanding among some participants, as they request further clarification and explanation.
Participants express urgency due to an upcoming midterm, indicating that they are under pressure to grasp the concepts involved in the problem. There is mention of specific forces and relationships, but the discussion does not reach a consensus on the solution.
oahsen
there is another problem that i couldn't solve. it is about circular motion ;
a thin circular horizontal hoop of mass m and radius R rotates at frequency f about a vertical axis through its center. determine the tension within the hoop. (there is a hint : consider a tiny section of the hoop)
and the answer is 2*pi*m*R*f*f but how??
Hint: Find the total force acting on half the hoop. Where does that force come from?
please give a bit more information
thanks for hint but i didnt understand again. could you give a bit more explanation. i have midterm on friday and still i couldn't solve some problems and that makes me very sadddd
Can you draw a free body diagram?
yes i can draw but there is only m*v*v/r in the diagram. maybe there can a tension but if so they will be perpendicular and how can i write a relationship between them?
You know the force on each little piece of the loop having mass dm = (m/2πr)dl = (m/2πr)(rdθ) is centripetal (dl is a tiny length of the arc of the hoop, and π is pi in a not very good font), so it can be set equal to d(m)v^2/r = (dm)rω^2. If you look at half the hoop, the force is in a different direction for each little piece, but by symmetry the total force is directed parallel to the axis of symmetry of the semicircle, i.e., in the direction of the force acting on the midpoint of the semicircle. If you break all the forces into components parallel and perpendicular to this direction, the sum of the perpendicular components is zero (by symmetry or by direct integration). The sum of the components parallel to this direction is the total force acting on that half of the hoop. The integral to find this sum is fairly easy. This force is provided by the other half of the hoop at the two points of contact where the halves are connected. At each contact point, the force is the tension in the hoop.
ok i understood. 2*pi*f*f*r= (dm/dtheta)*(v^2)/r
=m * a ( for a piece an it is equal
to the tension )
thanks a lot
  • · Replies 19 ·
  • · Replies 16 ·
