| Thread Closed |
Projectile Motion Range (please Help) |
Share Thread | Thread Tools |
| Oct31-06, 06:05 PM | #1 |
Question: How far will a stone travel over level ground if it is thrown upward at an angle of 31.0 degrees with respect to the horizontal and with a speed of 11.0m/s?
What is the maximum range that could be achieved with the same initial speed? I have tried to solve this with no sucess what i have done is Drawn a triangle with a angle being 31.0 degrees the opposite side from the angle is Vy the adjacent side is Vx the hypothesis is 11.0m/s then i drew a chart with X and Y X side of the chart I have Vx= 9.428840308 a=0 then on the y side i have Vy=5.665418824 a=-9.8 the Vf=0m/s I used the formula Vf=Vi+At and solved for time and got 0.578103962 then i used d=Vi*t+1/2At^2 and solved for D and got 1.637620735 for the first question (But was told this was not correct) For the second question i doubled the time and multiplied by Vx D=9.428840308 (1.15620784) and got 10.90169909 but it was wrong ! Is there anyone who might be able to help me Please???
| Oct31-06, 06:11 PM | #2 |
what is the final velocity in the Y direction? And why?
for your second question how do you maximize the distance you could travel? They gave you a hint : the SPEED is thesame but something else must be different. What must change? and Why did you double time?? |
| Oct31-06, 06:12 PM | #3 |
GOod grief you don't believe in rounding numbers do you????
If you've calculated, as it appears, the time taken for the vertical velocity to reach 0M/s, then you've calculated the time for the stone to reach it's maximum height, - it still has some way to go before it hits the ground. I would use here the equation x = V(i)t + 0.5 a t^2 with the vertical velocity and a = 9.8 but remembering that when the stone hits the ground its vertical displacement is zero because it started from ground level That will give you a time, then use this with the horizontal velocity (constant) to calculate the horizontal distance. |
| Oct31-06, 06:14 PM | #4 |
final velocity in y direction is 0 because at the apex it is not going anywhere
| Oct31-06, 06:18 PM | #5 |
But the apex is not the final velocity. It comes back down again.
| Oct31-06, 06:18 PM | #6 |
but is that the final velocity in the y direction for the WHOLE trip after all you are trying to find the time it took for the ENTIRE journey |
| Oct31-06, 06:21 PM | #7 |
I get x= 1.637600545 is this right? (i am too stressed to round any numbers LOL)
| Oct31-06, 06:22 PM | #8 |
| Oct31-06, 06:23 PM | #9 |
That's not what I got.
What to you get for the time? |
| Oct31-06, 06:25 PM | #10 |
i took 5.665418824(0.578103962)+0.5(-9.8)(0.57810396)^2 and got 1.637600545
| Oct31-06, 06:26 PM | #11 |
Recognitions:
If you didn't, do so. (Solve for t.) When you do so, plug that time into [tex]x(t)=11\cdot\cos(31)t[/tex] to get the total displacement. |
| Oct31-06, 06:30 PM | #12 |
to get the time i used the formula Vf=Vi+at
Vf=0m/s a= -9.8 Vi=5.665418824 (by 11.0sin(31.0)) and then i solved for time |
| Oct31-06, 06:33 PM | #13 |
after it has completed its entire flight what is the velocity in the Y just before it hits the ground? I certainly hope it isnt zero otherwise whatever ive been doing for these 6 odds years has been in vain! VAIN! and this world has no justice
| Oct31-06, 06:37 PM | #14 |
I don't understand? I am going by the example we did in class and for Vf we used 0 and this is at the apex
| Oct31-06, 06:40 PM | #15 |
Recognitions:
Btw, I suggest you do a few searches named 'projectile motion', this could do good.
| Oct31-06, 06:41 PM | #16 |
That would be good to calculate the maximum HEIGHT of the object, not the maximum distance it travels.
Throw a ball into the air. When it hits the ground, is the y velocity zero? Use intuition, it really helps sometimes |
| Oct31-06, 06:44 PM | #17 |
since im such a nice guy i drew a diagram for you
look at the diagram now tell me what do u think the velocity i nteh Y direction must be after thw whole trip? THINK before you answer but dont think too hard you are probably mixing up the type of questions |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Projectile Motion Range (please Help)
| projectile motion range | Introductory Physics Homework | 3 | ||
| Help! Maximizing Range of Projectile Motion! | Introductory Physics Homework | 5 | ||
| Projectile Motion: Range | Introductory Physics Homework | 3 | ||
| Projectile Motion: Range proof | Introductory Physics Homework | 0 | ||
