Pulling on a cylinder and energy lost to friction
The discussion focuses on calculating the energy lost to friction when a mass M = 1.35 kg pulls a spool of wire with an inner radius of r = 0.50 m and an outer radius of R = 0.65 m, which has a moment of inertia Icm = 1.06 kg*m². After the mass falls a distance D = 0.54 m, it reaches a speed of v = 70.200 cm/s. The key takeaway is that the energy lost to friction can be determined by comparing the initial and final energy states of the system, as friction prevents the conservation of mechanical energy.
  • Understanding of basic physics concepts such as energy conservation and friction.
  • Familiarity with rotational dynamics, specifically moment of inertia.
  • Knowledge of kinematic equations relating distance, speed, and acceleration.
  • Ability to perform energy calculations involving potential and kinetic energy.
  • Calculate the initial potential energy of the mass using the formula PE = M * g * D.
  • Determine the final kinetic energy of the mass and the spool using KE = 0.5 * Icm * (v/R)².
  • Analyze the energy difference to quantify the energy lost to friction.
  • Explore the implications of friction in rotational systems and its effect on energy efficiency.
This discussion is beneficial for physics students, educators, and anyone interested in understanding energy dynamics in mechanical systems, particularly in the context of rotational motion and frictional forces.
ThisIsWhyImABioMajor
A spool of thin wire (with inner radius r = 0.50 m, outer radius R = 0.65 m, and moment of inertia Icm = 1.06 kg*m2 pivots on a shaft. The wire is pulled down by a mass M = 1.35 kg. After falling a distance D = 0.54 m, starting from rest, the mass has a speed of v = 70.200 cm/s. Calculate the energy lost to friction during that time.
Not sure where even to begin! :confused:
Welcome to PF !
Please read our guidelines concerning homework which you agreed upon:
- post them in the appropriate homework section (in this case: intro physics; I'll move the thread after this post)
- show some work before others are even allowed to help you.
This policy is not to make life hard for you, on the contrary...
However, I'm going to give you a hint in approaching the problem:
if you know the energy at the beginning, and at the end, then the difference might have something to do with friction (because if there weren't any, both would be the same).
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 23 ·
