Solve Magnetism Problems: Probs 1, 4, 8 & 10
  • Thread starter Thread starter mustang
    Magnetism
This discussion addresses four specific magnetism problems involving protons and current-carrying wires. Problem 1 utilizes the formula F = qvB to determine the speed of a proton in a magnetic field of 4.70 x 10^-2 T, resulting in a speed of 1.34 x 10^5 m/s. Problem 4 also employs F = qvB to calculate the magnetic force on a proton moving at 1.5 x 10^7 m/s in a 4.7 T field, yielding a force of 1.12 x 10^-12 N. Problem 8 applies F = ILBsinθ to find the magnetic field strength perpendicular to a wire segment, resulting in 0.16 T. Finally, Problem 10 combines F = mg and F = ILBsinθ to determine the magnetic field strength required for a floating copper rod, calculated to be 0.13 T.
  • Understanding of magnetic force equations, specifically F = qvB and F = ILBsinθ
  • Knowledge of the charge of a proton, 1.6 x 10^-19 C
  • Familiarity with basic physics concepts such as mass, gravity (g = 9.81 m/s²), and current
  • Ability to rearrange equations to solve for unknown variables
  • Study the derivation and applications of the Lorentz force law
  • Explore the principles of electromagnetism related to current-carrying conductors
  • Investigate the effects of magnetic fields on charged particles in motion
  • Learn about free body diagrams and their use in solving physics problems
Students and educators in physics, particularly those focusing on electromagnetism, as well as engineers and professionals working with magnetic fields and forces in practical applications.
mustang
Problem 1.
A proton moves perpandicularly to a magnetic field that has a magnitude of 4.70*10^-2 T.
What is the speed of the particle if the magnitude of the magnetic force on it is 2.12*10^-14 N? Answer in m/s.
Note: What formula should I use?
Problem 4.
A proton moves straight upward (away from the ground) through a uniform magnetic field that points from east to west and has a magnitude of 4.7 T.
a. If the proton moves with a speed 1.5*10^7 m/s through this field, what is the magnitude of the force acting on it? Answer in N.
Problem 8.
The magnetic force on a straight 0.37m segment of wire carrying a current of 4.5 A is 0.60 N.
What is the magnitude of the component of the magnetic field that is perpendicular to the wire? Answer in T.
Note: What should i do first?
Problem 10.
Given: g=9.81m/s^2.
A thin 2.18m long copper rod in a uniform magnetic field has a mass of 52.2g. When the rod carries a current of 0.260 A, it floats in the magnetic field.
What is the field strength of the magnetic field? Answer in T.
NOte: Where do i start?
Originally posted by mustang
Problem 1.
Problem 4.
Take a close look at the equation for the magnetic force on a moving charged particle.
Problem 8.
Take a close look at the equation for the magnetic force on a current-carrying wire.
Problem 10.
Given: g=9.81m/s^2.
Draw a free body diagram, and balance the forces.
Problem 1: To solve this problem, you can use the formula F = qvB, where F is the magnetic force, q is the charge of the particle (in this case, the charge of a proton is 1.6*10^-19 C), v is the velocity of the particle, and B is the magnetic field strength. Rearrange the formula to solve for v, and plug in the given values to get v = 1.34*10^5 m/s.
Problem 4: To solve this problem, you can use the formula F = qvB, where F is the magnetic force, q is the charge of the particle (in this case, the charge of a proton is 1.6*10^-19 C), v is the velocity of the particle, and B is the magnetic field strength. Plug in the given values to get F = 1.12*10^-12 N.
Problem 8: To solve this problem, you can use the formula F = ILBsinθ, where F is the magnetic force, I is the current, L is the length of the wire, B is the magnetic field strength, and θ is the angle between the wire and the magnetic field. In this case, θ is 90 degrees since the wire is perpendicular to the field. Rearrange the formula to solve for B, and plug in the given values to get B = 0.16 T.
Problem 10: To solve this problem, you can use the formula F = mg = ILBsinθ, where F is the magnetic force, m is the mass of the rod, g is the acceleration due to gravity, I is the current, L is the length of the rod, B is the magnetic field strength, and θ is the angle between the rod and the magnetic field. In this case, θ is also 90 degrees since the rod is perpendicular to the field. Rearrange the formula to solve for B, and plug in the given values to get B = 0.13 T.
  • · Replies 23 ·
