Higher-order weak interaction decays
The discussion revolves around the decay process of certain exotic mesons, specifically the decay of B^{+} into D^{0} and \pi^{+}. Participants explore the weak interaction mechanisms involved, particularly focusing on higher-order processes and the complexities of Feynman diagram representations.
  • One participant describes the decay process involving multiple W boson exchanges and seeks clarification on how to represent it in a Feynman diagram.
  • Another participant outlines a sequence of interactions involving quark transformations leading to the final state of D^{0} and \pi^{+} mesons.
  • There is a correction regarding the quark content of the D^{0} meson, with a participant noting that it contains a c quark, not a cbar.
  • One participant expresses skepticism about the feasibility of the decay occurring as described, suggesting that it may require a new theoretical framework.
  • A later reply provides a detailed breakdown of how the decay could theoretically proceed, despite doubts about its observability due to the nature of the weak interactions involved.
Participants express differing views on the validity and feasibility of the decay process, with some proposing mechanisms while others question their practicality. The discussion remains unresolved regarding the likelihood of the decay occurring in practice.
Participants highlight the complexity of higher-order weak interactions and the potential for confusion in quark content and decay pathways. There are unresolved assumptions about the theoretical framework required for such decays.
MaximumTaco
Considering the decay of certain exotic mesons, such as the following:
[tex]B^{+} --> D^{0} \pi^{+}[/tex]
Apparently the decay proceeds via a weak interaction where multiple W boson exchanges occur.
I was trying to nut out how this actually occurs, and draw up a sensible Feynman diagram representation of the process, but i can't quite nut it out.
Recall that the B+ meson is comprised of a u and anti-b quark, and the D0 is a c and anti-up, and the Pi+ is an up and anti-down, FYR.
Could someone offer me any pointers as to how such decay process usually work? First-order weak process such as beta decay are pretty straightforward, but this idea seems a bit more tricky.
bbar-->cbar + W^+.
W^+--> u + dbar.
That u + cbar--> D^0.
The incoming u + dbar--> pi^+.
But doesn't the D^0 meson contain a c, not a cbar ?
Yes. You fooled me with your first equation. It should be
B^+--D^0bar+pi^+.
If you really meant D^0, then the diagram would be a mess and the decay never seen unless you have some completely new theory.
Could you tell me how the decay could proceed anyway, even though it might never occur in practice?
The final state you want, D_0 + pi^+ has the quarks [c ubar] and
[u dbar]. You could get that from [u bbar] by the steps:
1. bbar -->W^+ + cbar.
2. W^+ -->[c] + [dbar].
3. cbar --> W^- + dbar.
4. W^- + u --> d.
5. dbar +d --> [ubar] + (via strong intgeraction).
This leaves you with the right quarks for D_0 + pi^+.
The decay is doubly weak, so I cannot see how it could be observed.
  • · Replies 29 ·
10K
