Question on wire tension & hinge force
The discussion centers on calculating the hinge force components (Rx and Ry) and the tension (T) in a wire supporting a beam. The scenario involves a 55.0 kg person standing 1.85 m from the wall on a 5.65 m beam with a mass of 40.0 kg, connected to the wall by a wire at a 30-degree angle. The calculations require applying static equilibrium principles to determine the forces acting on the beam and the wire tension.
  • Understanding of static equilibrium in physics
  • Knowledge of force components and vector resolution
  • Familiarity with trigonometric functions, particularly sine and cosine
  • Basic principles of mechanics related to beams and supports
  • Study static equilibrium problems involving beams and supports
  • Learn about vector resolution and force component calculations
  • Explore trigonometric applications in physics, focusing on angles and force analysis
  • Review examples of tension in cables and wires in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors seeking to enhance their understanding of static equilibrium and force analysis in real-world applications.
student331
A person with mass 55.0 kg stands d = 1.85 m away from the wall on a x = 5.65 m beam. The mass of the beam is 40.0 kg. A wire connects the end of the beam to the opposite wall at an upward 30 degree angle. Find the hinge force components (Rx and Ry) and the tension (T) in the wire.
btw, the wall that the wire connects to is facing opposite the first wall which is connected to the beam.
This sounds like you're asking for help on a homework problem. There is a separate forum for homework help. You might want to repost this there.
  • · Replies 18 ·
