Angular Momentum of Rod Question
The problem involves a uniform thin rod rotating about a vertical axis and a bullet impacting it at an angle. The discussion centers on the conservation of angular momentum and the calculations related to the system's moment of inertia.
  • Participants discuss the application of conservation of angular momentum and the implications of inelastic collisions. There are attempts to relate translational momentum to angular momentum, with questions about the correctness of these approaches. The moment of inertia calculations are also scrutinized.
Some participants have provided guidance on the distinction between translational and angular momentum, emphasizing the need to calculate the angular momentum of the bullet before the collision. There is an ongoing exploration of the correct equations to use for the system.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. The original poster expresses uncertainty about their calculations and the application of principles, indicating a need for clarification on the concepts involved.
americanforest
http://loncapa2.physics.sc.edu/res/sc/gblanpied/courses/usclib/hrw/hrwpictures/12-42.jpg
A uniform thin rod of length 0.40 m and mass 3.0 kg can rotate in a horizontal plane about a vertical axis through its center. The rod is a rest when a 3.0-g bullet traveling in the horizontal plane of the rod is fired into one end of the rod. As viewed from above, the direction of the bullet velocity makes an angle of 60° with the rod (see the figure). If the bullet lodges in the rod and the angular velocity of the rod is 12.0 rad/s immediately after the collision, what is the magnitude of the bullet's velocity just before impact?
What I've done:
As I read this I thought of three ideas:
1. Conservation of Angular Momentum, [tex]P_b=L_r[/tex]
2. Inelastic Collision
3. Parrallel Axis Theorem (with the Mass of the Bullet at the end of the rod after it hits it.
First thing I tried was quite simple. I simply set [tex]P_b=L_r[/tex] but the velocity that I found was incorrect. Suspecting that I was neglecting using the angle, I then tried [tex]P_b\sin(\theta)=L_r[/tex]. This, however, also left me with an incorrect result. As I don't see anything wrong in my methods for finding velocity I think I may have made a mistake in calculating the Moment of Inertia of the rod in it's final state which I have as:
[tex]I_f=\frac{(m_r)(L^2)}{12}+\frac{(m_b)(L^2)}{4}[/tex]
and thus:
[tex]V_b=\frac{[\frac{(m_r)(L^2)}{12}+\frac{(m_b)(L^2)}{4}]\omega}{(m_b)\sin(\theta)}[/tex]
Where is the mistake here? I assume it is legal to convert from translational momentum to rotational momentum like this?
Incorrect. Use the angular momentum of the bullet instead of its translational momentum.
ehild
OK, so is this correct:
[tex]L_b=m(\frac{L}{2})^2\frac{V_b\sin(\theta)}{\frac{L}{2}}=L_d[/tex]
So, you cannot convert straight from Translational to Rotational Momentum? Why not?
Also, is the angular momentum equation for the rod+bullet correct from my first post?
You can not compare angular momentum with translational momentum. They are different quantities. The conservation of angular momentum means that the angular momentum of a system does not change when no external torgue is applied. The initial angular momentum is that of the bullet, as the rod is in rest. How do you calculate the angular momentum of the bullet before collision?
ehild
ehild
The angular momentum of the bullet relative to the centre of mass of the rod just before the collision is
[tex]L_b=m(\frac{L}{2})^2\frac{V_b\sin(\theta)}{\frac{L}{2}}[/tex]
I've got the answer, thanks for the help.
  • · Replies 71 ·
  • · Replies 17 ·
  • · Replies 62 ·
14K
  • · Replies 18 ·
