| Thread Closed |
Java help |
Share Thread | Thread Tools |
| Nov6-06, 08:36 PM | #1 |
Java help
Hello. I am writing a program, but I can't figure out how to do something. I want to do something like this:
Sample input: abcdeft 01234567 asfg Sample output: The length of line 1 is: 6 The length of line 2 is: 7 The length of line 3 is: 3 |
| Nov6-06, 08:38 PM | #2 |
So I want to input any number of lines and then I want to give the length of each one of those lines. I want to write it with a while loop and use a sentinel value so it knows when I want to quite entering lines of text. Once I enter the sentinel value the program then outputs the length of each line.
| Nov6-06, 08:43 PM | #3 |
Should I do it like this:
final String SENTINEL = stop; Scanner scan = new Scanner(System.in); String line = ""; int length = 0; int n = 0; while( !line.equals(SENTINEL) ) { line = scan.nextLine(); length = line.length();i n = n +1; } System.out.println("The length of line " + n + " is: " + length); |
| Nov6-06, 08:49 PM | #4 |
Java help
So my question is how do I get each n and length to show up (not just for the final line I enter)?
| Nov6-06, 08:50 PM | #5 |
Looks reasonable, except you'd need to put the System.out.println statement INSIDE the while loop. You want to print the length of every line, yes? Not just the last one?
- Warren |
| Nov6-06, 08:54 PM | #6 |
| Nov6-06, 08:55 PM | #7 |
Then you need to store the information somewhere, e.g. in an array or Vector.
- Warren |
| Nov6-06, 08:56 PM | #8 |
We have not yet covered arrays. Is there another way to do it?
| Nov6-06, 08:58 PM | #9 |
Then you do not yet have the resources to write this program.
- Warren |
| Nov6-06, 09:00 PM | #10 |
Could you help me write that with an array then?
| Nov6-06, 09:01 PM | #11 |
Do you know the maximum number of lines the user might enter? Arrays are of fixed length.
- Warrens |
| Nov6-06, 09:02 PM | #12 |
No. One of the things I want to do is write as many lines as I want ( not keep the number of lines a fixed number ).
What about a vector? |
| Nov6-06, 09:03 PM | #13 |
Oh, MAXIMUM number. I could just choose a large number that I would never use, right?
I will never use more than 10 lines. |
| Nov6-06, 09:13 PM | #14 |
If you intend to never read more than 10 lines, then you can make an array of ten integers, like this:
int lengths[10]; You'd then modify your for loop to store the line length in lengths[n]. After you're done reading input, you'd need another for loop (from 0 to n-1) to print out the information stored in that array. - Warren |
| Nov6-06, 09:13 PM | #15 |
Ok, hold on. Like I said, I am not familiar with arrays. So at the top where I am declaring all of the variables I would just write:
int lengths[10]; Then in the while loop I would do: length[n] = line.length(); Do I have to change the while loop to a for loop? |
| Nov10-06, 12:50 AM | #16 |
I would suggest an ArrayList, It is similar to an Array but can grow or shrink to fit the needed size. ArrayList lengths = new ArrayList();
lengths.add(line.length); // adds the line length to the end of the list lengths lengths.get( enter a line number here); // returns the length of the line at the specified index of the list, for example if you place 3 in the parantheses then it returns the length of the thrid line, provided there is a third entry in your arraylist |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Java help
| java q | Computing & Technology | 3 | ||
| Help! Cant get Java! | Computing & Technology | 3 | ||
| new to java | Programming & Comp Sci | 7 | ||
| Help in Java 3D | Computing & Technology | 0 | ||
| Java | Introductory Physics Homework | 13 | ||
