Joint and conditional distributions
The discussion revolves around evaluating the joint and conditional distributions of two independent Chi-square random variables, X and Y, with different degrees of freedom. The specific problem involves calculating the probability P(X>a, X-Y>0) and exploring the implications of conditional probabilities in this context.
  • One participant seeks to evaluate P(X>a, X-Y>0) using Bayes' theorem, expressing it in terms of conditional probabilities.
  • Another participant suggests that the condition can be simplified to P(X>a, X>Y) = P(X>max{a,Y}), noting that this changes based on the relationship between a and Y.
  • A participant questions the necessity of the conditional probability formula and points out that the evaluation hinges on the random nature of Y.
  • There is a discussion about the lack of a set threshold for determining when P(X>a,X>Y) transitions from P(X>a) to P(X>Y), emphasizing the randomness of Y.
  • One participant proposes that the cumulative distribution function (CDF) of max{a,Y} could be a linear combination of CDF(Y|Y>a) and the mass point Y=a, but acknowledges the complexity of further evaluating the related random variable.
Participants express differing views on the approach to evaluating the conditional probabilities and the implications of the random variable Y. There is no consensus on a definitive method for calculating P(X>a,X>Y) or establishing a threshold.
Participants note the dependence on the random variable Y and the implications for evaluating the maximum function, indicating that the problem is complex and lacks straightforward resolution.
OFDM
I'm having a problem evaluating a distribution-
Suppose X and Y are Chi-square random variables, and a is some
constant greater than 0. X and Y are independent, but not identically distributed (they have different DOFs).
I want to find
P(X>a,X-Y>0). So I use Bayes' theorem to write
P(X>a,X-Y>0)
=P(X>a | X-Y > 0)*P(X-Y>0)
=P(X>a| X>Y)*P(X>Y)
Now I have an expression for P(X>a) and P(X>Y), but I am at a
loss as to how to evaluate the conditional distribution P(X>a|
X>Y).
I figured out that if Y was a constant (rather than a random variable), then I could write
P(X>a| X>Y) = { 1 if Y>a
{ P(X>a)/P(X>Y) if Y<a
But this does not help evalaute the distribution because I requires knowledge of the value of random variable Y.
Any help will be much appreciated.
Why are you going through the conditional probability formula?
(X>a, X>Y) if and only if (X > max{a,Y}) or (X - max{a,Y} > 0). Just an observation.
Thanks, that is a good observation. So now I know that
P(X>a,X>Y) = P(X>max(a,Y)). I would like to express this as some function of P(X>a) and P(X>Y) . That is, I know that
P(X>a,X>Y) = [ P(X>a) if a>Y
[ P(X>Y) if a<Y
but I only know a, not Y (since Y is an RV). So, in other words, is there a way to determine the 'threshold' at which P(X>a,X>Y) changes from P(X>a) to P(X>Y)?
BTW, is this homework? If it is, this is not the place to post it.
There is no set threshold because -- as you posted -- Y is a r.v. By implication so is max{a,Y}. I am guessing that the cdf of max{a,Y} would be some linear combination of CDF(Y|Y>a) and the mass point Y=a (representing all the occurances of Y<a). Even after obtaining CDF(max{a,Y}) you still need to figure out the CDF of the related r.v. (X - max{a,Y}).
  • · Replies 30 ·
