Question involving potentials and spherical conductors/capacitors/things
This discussion centers on the electric potential of a spherical conductor of radius a placed within a larger spherical conductor of radius b, with an outer radius of c. When the inner conductor is charged with a charge Q, the outer conductor's inner surface acquires a charge of -Q, while the outer surface retains a charge of Q. The potential between the conductors is expressed as kQ/(rbc)*[bc-r(b-c)], highlighting the additive nature of electric potentials and the implications of Gauss's Law, which states that the electric field inside a spherically symmetric charge distribution is zero.
  • Understanding of electric potential and charge distributions
  • Familiarity with Gauss's Law
  • Knowledge of spherical conductors and their properties
  • Basic calculus for potential calculations
  • Study the application of Gauss's Law in electrostatics
  • Explore the concept of electric potential in spherical coordinates
  • Learn about superposition principles in electric fields
  • Investigate the behavior of conductors in electrostatic equilibrium
Students and professionals in physics, electrical engineering, and anyone interested in understanding electrostatics and the behavior of spherical conductors and capacitors.
schattenjaeger
Say you have a spherical conductor of radius a located inside the cavity of a larger spherical conductor of radius b, and that the larger sphere's outer radius is c
If you charge the inner conductor at a to a charge Q, the inside part of the outer conductor becomes charged -Q and the outer outer part with Q again, ok, I got that
then it wanted the potential anywhere. I understand the potential outside the whole thing, the potential between b and c, but when r is from a to b I had trouble. I had the answer beforehand, which is kQ/(rbc)*[bc-r(b-c)] or I may've mixed that up
I see that if you unsimplify that it's like a sum of potentials. It's the potential between a and b, kQ/r, minus the potential AT the surface b(well, the Q is negative there so I guess you can just say plus the potential at b)plus the potential at c
Simple question: Why is it like that? Is there a more systematic way of reaching that answer? oh and of course the answer from a to b is like that one with r=a
It is the magic of 1/r^2 and Gauss and all that. Inside any spherically symmetric charge distribution the electric field is zero. That can be shown by direct integration, or by Gauss's Law. That means it takes zero work to move a test charge from one place to another inside a cavity surrounded by such a charge distributiuon, which means the potential due to that charge distribution is constant in that region.
The potential is additive (superposition). It's usually easier to work from the outside into add things up because the outer charges contribute only a constant potential to the inner regions.
  • · Replies 22 ·
