Solve Rigid Body Motion: Find Angle Between Axis & Invariable Line
The discussion focuses on solving a rigid body motion problem involving the relationship between the axis of rotation (ω), the axis of symmetry, and the invariable line (L). The key equation derived is tan^-1((Is-I)*tan(alpha)/(Is+ I*tan(alpha)^2), which relates the angle between the rotation axis and the invariable line to the moment of inertia (I) and the symmetry moment of inertia (Is). The Euler equations are utilized to express the angular momentum components, and the relationship between angles alpha and beta is explored to clarify the dynamics of the system.
  • Understanding of rigid body dynamics
  • Familiarity with Euler equations
  • Knowledge of moment of inertia concepts
  • Basic vector calculus, particularly cross products
  • Study the derivation of Euler equations in rigid body motion
  • Learn about the moment of inertia tensor and its applications
  • Explore the relationship between angular momentum and rotation axes
  • Investigate the use of cross products in determining angles between vectors
Students and professionals in physics, mechanical engineering, and robotics who are dealing with rigid body dynamics and require a deeper understanding of rotational motion and angular momentum relationships.
schuksj
I am having problems figuring out this problem. A rigid body having an axis of symmetry rotates freely about a fixed point under no torques. If alpha is the angle nbetween the axis of symmetry and hte instantous axis of rotaiton, show that he angle between the axis of rotaiton(omega) and the invariable line(L) is tan^-1((Is-I)*tan(alpha)/(Is+ I*tan(alpha)^2)).
Using Euler equations:
omega y'=omega*sin(alpha)
omega z'=omega*cos(alpha)
Ly'=I*omega*sin(alpha)
Lz'=Is*omega*cos(alpha)
and Ly'/Lz'=tan(theta)=I/Is=tan(alpha)
Would the cross product of omega and L give me the angle between the axis of rotation and the invariable line? I am not sure how to begin this problem or if this is the right start.
What exactly are I and Is? I see the possibility of another angle in the problem. If alpha is the angle between the symmetry axis and omega (it looks like you have used z as the symmetry axis), then there is some angle beta between the symmetry axis and the angular momentum. That would make
Ly'=L*sin(beta)
Lz'=L*cos(beta)
The angle theta would be (alpha - beta). The components of L are related to the components of ω by the moment of inertial tensor. If you know the components of L in terms of ω then you can find the magnitude of L and cross product L x ω as you suggested to find sin(theta) and theta.
  • · Replies 23 ·
