Differential equation word problem
The problem involves an aircraft flying towards the origin while experiencing a constant wind. The goal is to determine the path of the aircraft based on its airspeed and the wind's influence.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the aircraft's position and its velocity components, questioning how to express these in terms of the given speeds and angles. There are attempts to derive differential equations based on the slope of the tangent to the path.
Some participants have provided insights into the relationship between the aircraft's motion and the wind, while others are still seeking clarification on how to express the derivatives dx/dt and dy/dt. There is an ongoing exploration of the correct slopes and relationships involved in the problem.
Participants are navigating potential misunderstandings regarding the aircraft's orientation and the implications for the slope of its path. There is a mix-up regarding the reference points for the aircraft's trajectory.
bobbyz
The problem starts by saying that an aircraft is flying such that it's longitudnal axis always points towards the point (0,0). The plane itself starts at some point on the x-axis (say like (10,0)). The plane always has a constant airspeed, and experiences a constant wind blowing "north"
We want to find the path the aircraft takes
My solution so far:
Let s1=speed of the plane
s2=speed of the wind
theta=angle of the plane at time t
Find sin(theta) and cos(theta) in terms of x and y:
y=r sin(theta) and x=r cos(theta)
I think this is right if I remember my calc correctly, but I am not sure if r can be written using the speeds s1 and s2?
The next part of the question asks us to find dx/dt and dy/dt in terms of x,y,s1, and s2:
I am not sure how to do this part. I think I should break up the planes velocity into its components parallel to the axis but that is as far as I have gotten. If I could have help here I think I could finish the rest of the problem, but I don't want to mess up my initial work and do the whole problem wrong.
Thanks
Since the airplane is always "pointed toward" (10, 0), if it is at (x,y) then the tangent line to its path is the line from (10,0) to (x,y) which has slope y/(x-10). That means that, along its path dy/dx= y/(x-10), a simple separable differential equation. You can solve that for y as a function of x. Let its velocity vector with respect to the air by <u, v> and the wind's velocity be <0,w>. Then its velocity vector with respect to the ground is <u, v+ w> so dx/dt= u, dy/dt= v+ w. While w is a constant, u and v are not but the fact that the airplane's airspeed is a constant means that [itex]\sqrt{u^2+ w^2}= C[/itex] is a constant. You should be able to put that together with y as a function of x to find dx/dt and dy/dt in terms of the constants w and C.
I think you made some errors HallsofIvy.
The plane is always pointed towards (0,0). This would mean that the tangent line slope is y/x. Am I right?
Also, if anyone reads this, I am still having trouble finding dx/dt and dy/dt.
I have found that the total x direction motion over time can be found by x=Sa(x/sqrt(x^2+y^2)) and the total y motion over time can be found by y=Sa(y/sqrt(x^2+y^2)) +Sw. I am pretty sure that this is right but my question is how to dx/dt and dy/dt in terms of x,y,Sa,and Sw. Any help would be helpful. Thanks
Yes, I got (0,0) and (10,0) mixed up!
