How Does Potential Drop Equal Supplied Voltage in a Resistance-Free Circuit?
The discussion revolves around the relationship between supplied voltage and potential drop in an electrical circuit, particularly focusing on scenarios involving a battery and resistance-free connections. Participants explore the implications of having no electrical devices in the circuit and question how potential drop can equal the supplied voltage in such cases.
  • Participants examine the concept of potential drop in the absence of resistive loads, questioning whether a circuit can exist without them. There are discussions about the implications of an open circuit and the behavior of voltage in such scenarios.
The conversation is ongoing, with various interpretations being explored. Some participants suggest looking at the situation through the lens of Ohm's Law, while others emphasize the importance of considering real-world factors such as internal resistance in batteries. There is no explicit consensus yet, but multiple perspectives are being shared.
Participants note the distinction between ideal and real-world components, highlighting that resistance-free wires do not exist in practical applications, which may influence the understanding of voltage and current in a circuit.
danago
Hey. I've been told that the total voltage supplied to an electrical series circuit will equal the sum of the potential drop across the circuit. I am a bit confused.
Lets say i have a 12V battery in a circuit, so each coulomb of charge obtains 12J of potential energy. What if there are no electrical devices? How can the potential drop equal the supplied potential difference?
I'm not quite sure, but if there were no electrical devices in the circuit, wouldn't that mean that there is zero potential drop?
Well, yes. But then you don't really have a circuit since you need some sort of resistor to make your circuit non-trivial.
A power source give you a voltage increase, and current flowing through loads gives you voltage drops. When you have a battery sitting there open circuit, there is no external current flow, so all you have is the battery voltage. When you connect it to an external circuit (like say two resistors in series), the sum of the voltage drops will equal the applied potential. So if you add up the voltage drops going around a complete loop, you get a negative voltage drop (voltage increase) at any sources, and positive drops at loads. The sum around the loop will equal zero.
Yes, if you need further explanation look up Kirchoff's Voltage Law.
Im still not understanding why though. If i use a 12V battery, it means there will be a total of 12V potential drop around the circuit, right? Let's say i hooked up each terminal of a battery with a resistance free wire. How does this law still apply?
I do not know a lot of E&M theory as I am a humble EE, but I think if you look at it in terms of Ohm's Law it might make more sense mathematically.
Ohm's Law is I = V/R. Since R = 0 across the resistance-free wire, I = infinity. Thus, voltage across the circuit can mathematically be anything, even 12 V.
Someone else may come along and correct me.
There's no such thing as a resistance free wire (except for a superconductor, but that's another subject).
Let's say you hook up an 18AWG wire across the battery, and the wire's resistance is a few milliOhms. A real battery (as with any real power source) has an internal resistance associated with its particular battery chemistry. So you model the battery as an ideal voltage source (zero output resistance) in series with the battery's output resistance. The short circuit draws a large current from the battery, and the source resistance of the battery limits the short circuit current.
Don't get caught up in the trap of thinking of real world things like batteries and wires in their simplified ideal model terms. Instead, look at real world things and understand how to model them in terms of combinations of ideal elements. That's what you do with SPICE simulations of real circuits, for example.
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 23 ·
