Figure skater spinning (rate of rotation)
The discussion revolves around a figure skater's change in rate of rotation as she pulls her arms in, which affects her rotational inertia. The problem involves concepts from rotational dynamics and conservation of angular momentum.
  • Participants discuss the conservation of angular momentum and how to relate the initial and final states of the skater's rotation. Questions arise about the relevance of time in the context of the problem, and there is confusion regarding the mathematical expression of the change in rotational inertia.
Participants are actively engaging with the problem, clarifying the relationship between rotational inertia and angular velocity. Some have made progress in expressing the problem mathematically, while others are still grappling with the concepts involved.
There is a specific focus on the percentage reduction of the skater's rotational inertia, which is noted to be 68.0% of its original value. This detail is crucial for understanding the conservation of angular momentum in this scenario.
kbyws37
A figure skater is spinning at a rate of 1.40 rev/s with her arms outstretched. She then draws her arms into her chest, reducing her rotational inertia to 68.0% of its original value. What is her new rate of rotation?
I am having trouble starting this problem.
I know that
(I)(alpha) = (I)(omega)(t)
however, the problem doesn't mention time..
What physical quantity is conserved in this problem?
Angular momentum is conserved.
So...
(I1)(omega1) = (I2)(omega2)
however i am confused as to how to find omega when i do not have time
Where do you see time mentioned in that equation? What makes you think you need it? (It doesn't matter how fast or how slowly the skater pulls her arms in, since all you care about is the end result.)
sorry i am struggling in physics so i don't really understand.
so
if she reduces her inertia by 68% of its original value...
it would be 0.68*omega
I don't know where to start
kbyws37 said:
so
Express that mathematically. If her original rotational inertia is I1, what's I2? Note that the precise instructions were:
reducing her rotational inertia to 68.0% of its original value​
That's "to", not "by".
ok thanks. i got it
1.40 rev/s = (0.68)I2
= 2.06 rev/s
Good! I'll rewrite it more systematically.
Conservation of angular momentum says:
Given:
omega1 = 1.4 rev/s
I2 = 0.68 I1
So:
(I1)(1.40 rev/s) = (0.68 I1)(omega2)
(1.40 rev/s) = (0.68)(omega2)
omega2 = (1.40 rev/s)/(0.68)
  • · Replies 20 ·
13K
  • · Replies 35 ·
  • · Replies 16 ·
16K
