How to Balance a See-Saw with Different Weights?
  • Thread starter Thread starter needhelp83
The discussion focuses on calculating the pivot point for balancing a see-saw with unequal weights. A 67-kg adult and a 23-kg child are positioned at opposite ends of a 10-meter board. The fulcrum must be placed at 2.56 meters from the adult's end to achieve balance, as derived from the equation 67d = (10 - d)23. This setup confirms that the calculations are accurate and the distance d should be clearly defined from the adult's position.
  • Understanding of basic physics principles, specifically torque and balance.
  • Familiarity with algebraic equations and solving for variables.
  • Knowledge of weight measurement in kilograms.
  • Concept of lever arms in mechanics.
  • Study the principles of torque and equilibrium in physics.
  • Learn how to apply algebraic methods to solve balance problems.
  • Explore real-world applications of levers and see-saws in engineering.
  • Investigate the effects of varying weights and distances on balance in practical scenarios.
Students in physics, educators teaching mechanics, and anyone interested in practical applications of balance and torque principles.
needhelp83
A 67-kg adult sits at one end of a 10-m board, on the other end of which sits his 23-kg child. Where should the pivot point be placed so the board (ignore its mass) is balanced?
67d=(10-d)23
67d=230-23d
90d=230
d=2.56 m
The fulcrum should be at 2.56 m
Have I set this up right
Looks okay.
Looks okay to me, although you should state where your distance d is to me measured from.
Edit: Too slow again
  • · Replies 26 ·
