Energy Conservation of an object on an incline
The discussion centers on the energy conservation of a 1kg object sliding down a 4m high incline at 53 degrees, initially moving at 2m/s. The object travels 3m horizontally before ascending a 37-degree incline. The participant calculated the distance traveled up the incline, arriving at 2.41m, while the correct answer is 1.95m as per the textbook. The discrepancy arises from a miscalculation in the application of energy conservation principles and the need to adjust for the incline's angle using the sine function.
  • Understanding of basic physics concepts, specifically energy conservation.
  • Familiarity with kinematic equations and their applications.
  • Knowledge of trigonometric functions, particularly sine and cosine.
  • Experience with friction coefficients and their impact on motion.
  • Review the principles of energy conservation in physics.
  • Learn how to apply kinematic equations in inclined plane scenarios.
  • Study the effects of friction on motion and energy loss.
  • Explore trigonometric applications in physics problems, particularly in incline calculations.
Students studying physics, educators teaching energy conservation principles, and anyone interested in solving problems related to motion on inclined planes.
inner08
An 1kg object is sliding down a 4m high incline which is inclined at 53 degrees. The initial speed is 2m/s. It then slides on a horizontal section 3m long which is at ground level and then slides up an incline plane that is inclined at 37 degrees. All surfaces have a kinetic coefficient of uc = 0.4. What distance will the object travel up the 37 degree incline before stopping?
Work Done:
Starting off Values:
Vi = 2m/s
Vf = ?
d = 3.19 (using trig)
m = 1kg
uc = 0.4
I drew a diagram and then I figured I would use the laws of conservation formula. I know their is kinetic and potential energy when the object is at a certain height. When the object is on the horizontal surface, their will only be kinetic and friction forces acting on it. So I thought i'd find the object's final speed on the 53degree incline (1/2mVf^2 = 1/2mVi^2 + mgh -fx). After I found Vf, I used that as the new initial speed for the horizontal surface. I then thought i'd find the final speed on the horizontal speed using the laws of conservation of energy (1/2mVf^2 = 1/2mVi^2 -fx). Finally, I took this value and used it as the new initial speed as the object is about to move up the 37 degree incline. I substituted it in the formula: mgh = 1/2mVi^2 - fx.
I keep getting an answer like 2.41m but the answer in the book is 1.95m. I'm not quite sure where I went wrong?
Your idea is right, you may want to re-check you calculations. Also, h is not the required answer - it's h/sin(37).
  • · Replies 33 ·
