Is A invertible if {v1, v2} and {Av1, Av2} are linearly independent sets?
  • Context: Graduate
  • Thread starter Thread starter yanyin
    Explain
The discussion centers on the linear dependence and independence of vector sets transformed by a 3x3 matrix A. It is established that if A is invertible, then the linear independence of a set {v1, v2, v3} in R^3 guarantees the linear independence of the transformed set {Av1, Av2, Av3}. Conversely, if {v1, v2} is linearly independent but {Av1, Av2} is not, A cannot be invertible. The discussion also confirms that if the product of two matrices AB is invertible, matrix B must also be invertible.
  • Understanding of linear dependence and independence in vector spaces
  • Knowledge of 3x3 matrix properties and operations
  • Familiarity with the concept of matrix invertibility
  • Basic linear algebra concepts, including kernel and span
  • Study the properties of invertible matrices in linear algebra
  • Learn about the implications of linear transformations on vector spaces
  • Explore the relationship between matrix products and their invertibility
  • Investigate the concepts of kernel and image in the context of linear mappings
Students of linear algebra, mathematicians, and anyone interested in understanding the implications of matrix transformations on vector spaces and their properties.
yanyin
explain why each of the following statemens is either true of false.
(a) if A is a 3X3 matrix and {v1, v2, v3} is linearly dependent set of vectors in R^3, then {Av1, Av2, Av3} is also a linearly dependent set.
(b) if A is a 3X3 invertible matrix and {v1, v2, v3} is a linearly independent set of vectors in R^3, then {Av1, Av2, Av3} is also a linearly independent set.
(c) if A is a 3X3 matrix and {v1, v2, v3} is a linearly independent set of vectors in R^3 for which {Av1, Av2, Av3} is also a linearly independent set, then the matrix A must be invertible.
(d) If A is a 3X3 matrix and {v1, v2} is a linearly independent set of vectors in R^3 for which {Av1, Av2} is also a linearly independent set, then the matrix A must be invertible.
(e) if A and B are 3X3 matrices and the product AB is known to be invertible, then it follows that B is also invertible.
This looks like homewrok.
a. A is linear, use this fact and the definition of Linear Dependence
b. A is linear use this fact and the definition of L. D.
c. 3 L.I. vectors in 3-d space form a basis of the space, and thus any element of the kernel would be in their span, write down such a notional element and use the hypotheses in the question
d. suppose B is not invertible, let v be non-zero and in the kernel. what is ABv?
(a) This statement is false. If {v1, v2, v3} is linearly dependent, it means that at least one of the vectors can be written as a linear combination of the others. This means that at least one of the vectors in {Av1, Av2, Av3} can also be written as a linear combination of the others, making the set linearly dependent.
(b) This statement is true. If A is an invertible matrix, it means that it has a unique inverse. This means that for any vector x in R^3, there exists a unique vector y in R^3 such that Ax=y. If {v1, v2, v3} is linearly independent, it means that none of the vectors can be written as a linear combination of the others. This property carries over to {Av1, Av2, Av3}, making it linearly independent as well.
(c) This statement is true. If {v1, v2, v3} is linearly independent and {Av1, Av2, Av3} is also linearly independent, it means that A has a unique inverse. This is because if A did not have a unique inverse, it would mean that there exists a non-zero vector x such that Ax=0, which would contradict the linear independence of {v1, v2, v3}.
(d) This statement is false. Similar to part (a), if {v1, v2} is linearly independent, it does not necessarily mean that {Av1, Av2} is also linearly independent. This depends on the specific values of A and the vectors v1 and v2.
(e) This statement is true. If AB is invertible, it means that it has a unique inverse. This means that there exists a unique matrix C such that (AB)C=I, where I is the identity matrix. This implies that B must also have a unique inverse, as it can be written as (AB)C=C^-1, where C^-1 is the inverse of C.
9K
  • · Replies 17 ·
