Calculating EMF from Coils in Rotating Magnetic Field
The discussion revolves around calculating the electromotive force (emf) generated by two coils in a rotating magnetic field, specifically focusing on the effects of area and flux in the context of electromagnetic induction.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between the area vector and the magnetic field, questioning why certain dot products yield zero. There is also a focus on the implications of choosing different areas for integration and how that affects the calculated flux.
Participants are actively questioning the assumptions regarding the area of integration and its impact on the flux calculation. Some guidance has been provided regarding the constancy of the integral value when bounded by the same path, but there is no consensus on the implications of varying the area chosen for integration.
There is an ongoing discussion about the effects of mutual inductance being ignored and the implications of integrating over different surfaces that enclose the same path. Participants express uncertainty about the relationship between area size and flux magnitude.
Lonley_Shepherd
To find the emf generated by two ten turn coils, the planes of which are at 60 degrees in a radial magnetic field B=Bcos(theta)sin(omega*t) in the direction Ar, that rotates with omega rad/sec at the instant when the coil A1A2 makes an angle alpha with the plane of the maximum flux density.
Now to compute the emf we will ignore the effect of mutual inductance and will just calculate the field for each coil then add them.
we have: emf = -N (integral) dB/dt . ds + N (integral) v x B . dL
my problem is with the first term, the S area vector is in the direction of A(phi) as shown (talking about the A1A2 coil here) so the dot product result will be zero even though the differential of B is not zero.
now i checked it with my tutor then he says we have to consider another area as the flux is clearly not zero (not that clear to me), so:
ds= r*d(phi)*dz Ar to get a value for the flux in the loop.. !
what i can manage so far that he chose another area that enclosed the same path, but isn't the value of that term going to increase if we choose larger areas, so the more the area "chosen" the more the flux!.. then there's no exact magnitude for any area integral .. thanks for your help
Moved to homework forum.
Why is A(phi) dot B zero? In your figure, they are not at right angles to each other.
the three coordinate directions am using are: A(r) A(phi) and A(z)
isnt A(r) . anything but A(r) zero?? as in A(x) . A(y) is zero
PS: i am not really asking about that particular question its the concept of intergrating over a surface that encloses a path, as explained in the previous post.
thank you
It won't include a larger value of B dot dS. If the area is bounded by the same path, then the integral of the dot product should be the same. Like if the surface is a flat disk or a hemisphere, if the equator is the bounding path for each, then the integral of the dot product should be the same.
okay.. can u give me a numerical example for that..
if B= B(t) A(r) then it will move out of the integral sign and the only term remaining is the (integral) ds , so the more the area chosen the higher the magnitude value of that term.. please help me with that
