Thread Closed
Pressure in a tank/pipe
Share Thread Thread Tools
Nov13-06, 02:53 PM   #1
Water flows steadily from an open tank. The elevation of point 1 is 10.0 m, and the elevation of points 2 and 3 is 2.00 m. The cross-sectional area at point 2 is .048 m^2; at point 3 it is .016 m^2. The area of the tank is very large compared with the cross-sectional area of the pipe.
I already got part A which tells us that the discharge rate is .2 m^3/s
Part B asks What is the gauge pressure at point 2?
I'm familiar with Bernoulli's equation and I thought I knew how to do the problem, but some how I got it wrong enough times to bring me down to one guess, so I want to be sure about what I'm doing.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov13-06, 03:11 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Shlllink
You will have to describe what points 1, 2 and 3 are in relation to the tank and pipe and what the cross-sectional areas refer to (eg. tank, pipe).
AM
Nov13-06, 05:25 PM   #3
i don't think there's enough there to tell, but if that discharge rate is for point 2 you could say that the speed of the water is due to the pressure and equate the velocity and pressure terms from the bernoulli. then solve for pressure.
v=Q/A (dischargre rate over area)
(v^2)/2=p/rho
that might work but impossible to say without a better description of question/diagram.
Thread Closed
Thread Tools
Similar Threads for: Pressure in a tank/pipe
Thread Forum Replies
reducing pressure in a pipe Introductory Physics Homework 3
Pressure in a tank General Physics 1
15.6 pressure in a pipe Introductory Physics Homework 4
pressure change inside a tank(s) Classical Physics 9
Water Pressure in Conical Tank Question Engineering Systems & Design 3
