Annoyinlgy easy problem with thermodynamics that I can't get my head around
The discussion revolves around solving a thermodynamics problem involving the latent heat of vaporization for water at 1 atmosphere and 100 degrees Celsius, which is 2268 J/kg. To find the volume occupied by 1g of steam, the ideal gas law (PV = nRT) is applied, where the number of moles is calculated using the molecular mass of water. The latent heat of vaporization is defined as the energy required for phase change without temperature increase. The first law of thermodynamics is utilized to determine the change in internal energy (ΔU) as ΔU = Q - W, where Q is the heat energy and W is the work done during the phase change.
  • Understanding of latent heat of vaporization
  • Familiarity with the ideal gas law (PV = nRT)
  • Knowledge of the first law of thermodynamics
  • Ability to calculate molecular mass of substances
  • Learn how to apply the ideal gas law to various thermodynamic problems
  • Study the concept of latent heat and its applications in phase changes
  • Explore the first law of thermodynamics in detail, including its implications
  • Practice calculating work done during phase changes using W = PΔV
Students studying physics, particularly those focusing on thermodynamics, as well as educators looking to clarify concepts related to phase changes and energy calculations.
Claire84
I'm just answering a thermodynamics problem of my Physics homework and I just can't get my head around it here. I'll give you the quesion here, and the reason I don't get it is because you're given the mass of the substamnce as opposed to the number of moles etc...
The latent heat of vaporisation for water at a pressure of 1 atmosphere and at 100 degrees C is 2268 J/kg.
Assuming that the steam behaves as an ideal gasm calculate thee volume occupied by 1g of steam under these conditions. Hence calculate the work performed by 1g as it changes from liquid to gas. Using the forst law of thermodynamics, calculate the change in the internal energy of 1g of the water when it changes to gas.
What does it mean by the latent heat as well? We've never used that term in lectures before. Thanks for your help!
To get the number of moles, you will need the molecular mass of water (you can look it up for H and O on a periodic table, and combine accordingly).
The latent heat of vaporization is the amount of heat required to change the phase from liquid to gas. It costs that much heat to change phase, and results in no increase in temperature.
There is a nice graphic at this website:
HyperPhysics
In the bubble map, click on "Heat and Thermodynamics", then in the next one click on "Phase Changes".
I understand that thermodynamics can be a challenging subject and it's not uncommon to struggle with certain problems. It's important to remember that it takes time and practice to fully grasp these concepts.
In regards to your specific question, the latent heat of vaporization is the amount of energy required to change a substance from a liquid to a gas at a constant temperature. This is different from the specific heat, which is the amount of energy required to change the temperature of a substance.
To solve this problem, you will need to use the equation Q = m*L, where Q is the heat energy, m is the mass, and L is the latent heat of vaporization. You are given the mass of the substance, so you can use this equation to calculate the heat energy required for the phase change.
As for the volume and work calculations, you will need to use the ideal gas law equation (PV = nRT) to solve for the volume of 1g of steam. Remember that the number of moles (n) can be calculated by dividing the mass by the molar mass of water. From there, you can use the work equation (W = PΔV) to calculate the work performed during the phase change.
Finally, the first law of thermodynamics states that the change in internal energy (ΔU) is equal to the heat energy (Q) minus the work (W). So, after calculating the heat energy and work, you can use this equation to find the change in internal energy for 1g of water as it changes from liquid to gas.
I hope this helps clarify the problem for you. Remember to take your time and break down the problem into smaller, more manageable steps. Don't hesitate to ask for help from your teacher or classmates if needed. Good luck with your homework!
