Coupled Forced Oscillators- Small Question-
The discussion focuses on the dynamics of a triatomic molecule consisting of two masses (m) at the ends and one mass (2m) in the center, connected by springs with spring constant k. The highest frequency mode is identified as ω² = 2k/m, occurring when the end masses oscillate in phase while the middle mass oscillates in counterphase. The question posed is which mass should be excited to achieve optimal resonance with the highest frequency mode. It is concluded that exciting the middle mass may require less energy for resonance.
  • Understanding of coupled oscillators and harmonic motion
  • Familiarity with normal mode analysis
  • Knowledge of resonance and frequency in mechanical systems
  • Basic principles of spring-mass systems
  • Research the principles of coupled oscillators in mechanical systems
  • Learn about normal mode analysis in triatomic molecules
  • Explore resonance phenomena and energy transfer in oscillatory systems
  • Study the effects of different excitation methods on oscillation modes
Students and researchers in physics, particularly those studying mechanical vibrations, coupled oscillators, and resonance in molecular systems.
Sol_Solved
I have the infamous triatomic molecule, with two m masses in the extremes and one 2m mass in the middle, joined by two k springs. I have worked all through the problem (found frequencies, normal modes, drawn configurations, initial conditions) with no hindrances, but I can't seem to get the last question.
It says: If a harmonic force is applied to one of the masses, to which would it be better to excite better the highest frequency mode?
Btw, the highest freq. mode is w^2= 2k/m and it happens with the first and third masses are in phase, with the middle mass in counterphase (1,-1,1)
How do I know which mass should I excite?
Thanks
Sol.[/color]
You can try both, and then see which one gives better resonance. My intuition tells me that the mass in the middle would be the one. I'm assuming that "better" means "less energy required."
Thanks
Sol.[/color]
