Solving U-Tube Fluid Problem: h1 Calculation
  • Thread starter Thread starter mirandasatterley
    Fluids U-tube
The problem involves a U-tube containing mercury and water, where the left arm has a larger cross-sectional area than the right. Participants are tasked with calculating the height of the mercury column in the left arm after adding water to the right arm, considering the principles of fluid statics and pressure equilibrium.
  • Participants discuss the relationship between the heights of the mercury and water columns, questioning the need for multiple height variables (h1 and h2) and exploring how to set up pressure equations based on fluid equilibrium.
Some participants have provided guidance on using pressure balance to relate the heights of the fluids, while others express confusion about the setup and interpretation of the problem. There is an ongoing exploration of how to express the relationship between the heights of mercury and water in the U-tube.
Participants note the importance of using a common reference level for pressure calculations and the implications of the cross-sectional areas of the U-tube arms on the fluid heights. There is mention of a diagram that is difficult to interpret, which may affect understanding.
mirandasatterley
The problem is;
“Mercury is poured into a U-tube. The left arm of the tube has cross-sectional area A1 of 10.0cm^2, and the right arm has a cross-sectional area A2 of 5.0cm^2. 100 grams of water are then poured into the right arm. (a) Determine the length of the water column in the right arm of the U-tube. (b) Given that the density of mercury is 13.6g/cm^3, what distance h does the mercury rise in the left arm?
For part (a) of this problem;
m(water) = d(water) V(water)
m(water) = d(water) A2 h(water)
h(water) = 20 cm
For part (b);
We use the point where the water and mercury meet in the right arm and the point horizontal to that in the left arm. And we get an equation;
P1 = P(atm) + d(Hg) g (h1 +h2), where hi is the height on the diagram from the horizontal line to the top of the mercury and h2 is the height from the horizontal line where the water and mercury meet to the horizontal line on the diagram.
P2 = P(atm) + d(water) g h (water)
P1 = P2
d(Hg) g (h1 + h2) = d(water) g h(water)
d(Hg) (h1 + h2) = d(water) h(water)
(h1 + h2) = (d(water) h(water))/ d(Hg)
= 0.0147 m,
But I only want to know h1. Any ideas how I could approach this?
It may be awhile before your diagram shows, and I am having some difficulty interpreting the words. I don't see why you need an h1 and h2. If the reference level is where the water meets the mercury, and you know the height of the water column, all you need is the height of the mercury above the reference level on the other side.
We were supposed to use a point where the horizontal reference line is lined up with the mercury on both sides of the u-tube. On the right side, this point is where the water meet the mercury, which is lower than the initial point where the mercury began to rise. So there is an h1 from where the mercury initially began to the height it got pushed up and h2 is from where the water meets the mercury on the left side to the initial position of the mercury.
OK. I can see your diagram now. It is very blurry and I cannot read the labels but I get the idea. You still should consider working from a reference height where you know the pressure on both sides is the same, and that would be a point in the mercury or at the mercury water boundary. You can relate all of your h values to this level and express your answer in the terms required.
Sorry about the blurry picture, i couldn't find a better one.
I'm trying to use;
(h1 +h2) = 1.47cm
and write another equation using all of the heights but when i sub them into solve for h1, the h1's cancel out.
I'm trying to use;
(h1 +h2) = 1.47cm
I don't think I can help you with your h1 and h2. I'm not convinced you have the conditions set up correctly in the first place. What I can tell you is that the pressure on both sides is the same at the same level only if you are in the mercury on both sides. If you draw a line across from the mercury water boundary to the other side, then the weight of the 100 grams of water on the right divided by the right-side area has to equal the weight of the mercury on the left above this level divided by the left-side area. This will let you find the height of mercury above this level on the left. You can figure out whatever h values you need fom there.
Okay, so;
m(water)/A(right) = m(Hg)/A(left)
m(Hg) = (m(water)A(left))/A(right)
If i sub in my values,
m(Hg) = 200g
Then are you suggesting that I do,
d(Hg)V(Hg) = 200g
d(Hg) A h(Hg) = 200g
And then to slove for h(Hg), and then find the h I need?
If this is right, is the A that I use the cross-sectional area on the right side?
Okay, so;
m(Hg) = 200g
d(Hg)V(Hg) = 200g
Ah(Hg) is the volume of the 200g of mercury on the side that contains only mercury. So which A is it?
You may soon start to recognize that all this calculation involving areas and volumes leads you back to the conclusion that the pressure at this reference level is
P = 1atm + ρ(Hg)*g*h(Hg) = 1atm + ρ(H2O)*g*h(H2O)
You already know h(H2O) = 20cm.
There is a final ingredient needed to relate the h(Hg) you will find to the original level before the water was added. What becomes of any mercury that is pushed out of the tube on the right?
The mercury remains in the tube, it is just pushed higher up the tube
So if the mercury surface on the right side goes down 3cm, what happens to the mercury surface on the left?
The left side of the tube is larger than the right side
Ok,,
Ok, so I am doing this question as well, and I got all the way to where this thread ends, found the height of the mercury column on the side with only mercury from the reference level where the water and mercury meet, done. However, I am stuck on how to get to the next part, i understand you must relate the volume of mercury pushed out of the right side tube to the volume of mercury on the left tube, i.e. V(right)Hg = V(left)Hg or h(right)(5.00cm^2) = h(left)(10.0cm^2) so h(left) = h(right)/2 right? but how do you find out how much mercury is pushed out of the tube?
Help Anyone?
If you have in fact found the height of the mercury in the left tube that is above the level where the water and mercury meet in the right tube, then you can use your statement above to find the level where the mercury was on both sides before the water was added. The volume of water below that level on the right is the volume of mercury that was pushed out of the right tube into the left tube. So what is the relationship between the height of the water below that level on the right and the height of the mercury that is above that level on the left?
ok so the total height of the mercury on the left is the height of mercury above the "equilibrium" (without water) line plus the height of water below that line, H(total) = H(Hg) + H(H20) and since they are of the same volume the height of the water is twice that of the height of the mercury, so H(total) = H(Hg) + 2(H(Hg)) so H(total)/3 = H(Hg) right?wow, I think I actually understand now! haha Its amazing how simple it seems once you get it. Thanks!
  • · Replies 18 ·
  • · Replies 17 ·
