Question that i am finding really hard
  • Thread starter Thread starter n_ds
    Hard
The problem involves determining the maximum acceleration of a 25kg object being hoisted vertically upward by a rope that can support a maximum load of 400N. The context is rooted in mechanics, specifically focusing on forces acting on an object in motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the net forces acting on the object, including gravitational force and the tension in the rope. There are attempts to clarify the relationship between these forces and how they relate to acceleration.
Participants are actively engaging with the problem, exploring the forces involved and how to calculate the net force. Some guidance has been provided regarding the identification of forces, and there is a progression towards formulating an equation for acceleration based on the net force.
There is an emphasis on understanding the forces acting on the object, including gravitational force and the tension from the rope, as well as the constraints of the maximum load the rope can handle.
n_ds
Hi
I tried this question a couple times, couldn't figure it out, thought maybe you guys could help.
1. The maximum load that can safely be supported by a rope in an overhead hoist is 400N. What is the maximum acceleration that can safely be given to a 25kg object being hoisted vertically upward?
I hope someone can help.
Thanks
What's the net force on the object if the rope is pulling as hard as it can?
Hint: Identify all forces acting on the object.
i can't figure out net force as i do not have acceleration...all i have is what is the max load the rope can take which is 400, the gravity which is -9.8 as it is going upwards and the 25 kg load
First find the net force, then use it to find the acceleration.
What forces act on the object? Hint: There are two forces acting. What is the magnitude and direction of each force?
I am not sure how to find the net force. Am i right in asuming that the 2 forces acting on the object, is the downward force of m*g and the upwards force of m*-g?
Gravity acts downward on the object with a force equal to mg. And, no, the upward force does not equal -mg, otherwise the net force would be zero... no acceleration at all.
Besides gravity, what force acts on the object? Hint: Isn't the rope attached to the object?
is it 400 N?
so Fnet = 400 - mg?
That's it!
ok so then this is what i think the solution would be
Fnet = 400 - mg
a= Fnet / m
a= (400 - (25)(9.8))/25
and that should give me the answer i need. That does that seem right to u?
Perfecto...
thanks so much for the help i really appreciate it
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 47 ·
