Fbd problems using Newtons second law
The discussion revolves around a problem involving Newton's second law, specifically relating to the forces acting on a wooden crate being pushed across a floor at constant velocity. The original poster seeks assistance in determining the coefficient of kinetic friction between the crate and the floor.
  • Participants discuss the balance of forces acting on the crate, noting that a horizontal force of 30.0 N must be countered by an equal frictional force due to the constant velocity. There are questions about how to relate the friction force to the coefficient of kinetic friction and the normal force.
Some participants have provided insights into the relationship between the applied force and the friction force, suggesting calculations involving the normal force and the weight of the crate. However, there appears to be a lack of clarity for some participants regarding the concepts involved, and no consensus has been reached on the approach to take.
Participants express a sense of urgency due to a looming deadline, and there are indications of confusion regarding the underlying principles of the problem, as well as the instructional support received from their teacher.
agentlxl
i need help with this problem please help
(If you use a horizontal force of 30.0 N to slide a 12.0kg wooden crate across a floor at a constant velocity, what is the coefficient of kinetic friction between the crate and the floor?)
PLZ HELP AHHHHH ITS DUE TMRW SO PLZ HELP
This is actually Newton 1...sum of forces = 0 when a body is at rest or moving at constant velocity. So 30N to the right must be balanced by the friction force acting left. Calculate the magnitude of the friction force. Then how would you relate this force with u_k and the Normal force?
listen i don't know anything my teacher just tells us to do it but doesn't explain so yeah that's my problem but thnx for answering
Don't be a quitter! You've got 30N on the crate to the right, and since the block is moving at constant velocity (not accelerating), Newton and Phanthom say that there must be a 30N force acting on it to the left. That's the only way the net force will add to 0, and that force to the left must be the friction force. And since friction force = (friction coefficient)(Normal force), and since Normal force is just the crate's weight, where weight = mg and where g = 9.8m/s/s, solve for the friction coefficient. I'm sure teach told you that. Now come on, chug it out.
  • · Replies 42 ·
