The Science Behind Salt and Wounds: Osmosis?
The discussion centers around the effects of salt (NaCl) on wounds, particularly exploring the mechanisms behind the pain experienced when salt is applied. Participants consider various aspects including osmosis, nerve reactions, and cellular responses, engaging with both theoretical and conceptual elements of the topic.
  • Some participants suggest that the dissociation of NaCl into Na+ and Cl- ions may contribute to the pain experienced when salt is applied to a wound.
  • There is speculation about whether Na+ or Cl- ions interact with nerve endings differently than other substances, potentially enhancing pain perception.
  • One participant proposes that a hypertonic solution caused by Na+ could damage cells, leading to pain, but acknowledges uncertainty about this explanation.
  • Another viewpoint suggests that the osmotic effect of salt on bodily fluids could lead to water leaving cells, which might register as pain due to the loss of protective skin layers over wounds.
  • Some participants discuss the role of Na+ and K+ ions in nerve impulses, suggesting that the influx of Na+ could trigger pain signals in the nervous system.
  • A later reply introduces the idea that sodium channels may have evolved in simple organisms, indicating a broader biological relevance of sodium in cellular processes.
Participants express a range of hypotheses regarding the mechanisms of pain caused by salt in wounds, with no clear consensus on the primary cause. Multiple competing views remain, particularly regarding the roles of osmotic pressure and nerve impulse generation.
Participants note limitations in their understanding, including the complexity of nerve responses and the potential for multiple factors contributing to pain. Some assumptions about cellular behavior and nerve function are not fully explored or resolved.
Link
Why does the wound hurt more if you pour salt (NaCl) on it? Does it have something to do with osmosis?
Biology news on Phys.org
Guess - the NaCl would dissociate and the ions would cause the pain.
Unless of course you were a slug and then you hypertonic solution would suck all of the fluid out of your body and you would die.
Nautica
but how? does Na+ or cl- ions react with nerves better than other substances or what
Too much of Na+ is not good. It will cause a hypertonic solution which will damgage the cell.
But Like I said I am not sure if this is what causes the pain, it was just a guess.
Nautica
I kinda agree with the slug idea - the reason you don't die if you touch salt, is that you are bigger than a slug, and you have an impermeable layer - the skin. With a wound, you lose the layer, and so in bodily fluids can make water leave your cells by osmosis. The damage would probably register as pain.
The Na+ and Cl-, if it somehow is absorbed into a nerve cell at different rates, would cause electrical imbalances which could push it over the threashold and cause them to fire - hence pain.
Half guessing.. half braining.
I'm going to agree with Jikx.
K+ and Na+ ions are both involved in nerve impulses. To begin a nerve impulse, the stimuli triggers a release of Na+ ions into the axon, which causes a chain reaction of Na+ being pumped in all through the nerve. Pain is a construct of our brains to interpret some nerve impulses. I'm guessing that this particular nerve impulse is the same as pain.
Though, like Jikx, I'm pretty much making an educated guess.
Wow! Is there a competition to see who can resurrect the oldest thread? ;-)
If you put salt on a necropost, will it hurt?
Yes. Mentors.
I cannot see dates on PF mobile.
Anyways it's not that hard considering you always have the link to the last page on the thread list.
I just happened to Google: "Why does salt in a wound cause pain" or something to that extent.
I agree with Jikx, but there may be more to it than a nerve firing, as sodium would indeed upset the osmotic pressure in cells, which they wouldn't like one bit. I think this may be why even choanoflagellates seem to have sodium channels (or at least the genes for them), even though said single cell animals obviously don'y have their own neurons!:
http://www.physorg.com/news/2011-05-sodium-channels-evolved-animals-nervous.html"
10K
  • · Replies 20 ·
  • · Replies 0 ·
14K
